Rear end on my Formula....
Old Nov 18, 2001 | 08:18 AM
admrlam's Avatar
I was over looking at 3rdgenformula.com, and they had charts listing available tachomoeter and speedo combonations... The chart says that the 305 LB9 with the A4 with a 5000rpm redline and a 6500 max came with the 3.23 or 3.27 rearend... Are those the only possibilities?
I dnot have my RPO sheet, cuz my cars in storage 100 miles away... ut assuming its all the stock parts (dash, engine, tranny and rear) that means i have one of these two, correct?
Old Nov 18, 2001 | 09:45 AM
Z28DJP1987's Avatar
Also add 2:73 ratio,which is the most common.
Old Nov 18, 2001 | 05:33 PM
admrlam's Avatar
Thats my question though.... because they had a different tach/speedo combination listed for the cars that had the 2.73 rear end...
Mine has the 5k redline and 6500 max, i dont have the longer range tach. Im relatively certain its the original dash too....
Anyone know for sure?
Old Nov 18, 2001 | 07:40 PM
Z28DJP1987's Avatar
5000 rpm redline is for the lb9 engine, now
the tach range should be 0 to 7000 rpm's.
Old Nov 18, 2001 | 10:48 PM
Stormshadow GTA's Avatar
my lb9 redlines at 5500
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
Lubricated by Mobil 1 Tri-Synthetic
It's for sale
Old Nov 19, 2001 | 09:50 AM
Z28DJP1987's Avatar
For your info the 5sp lb9 redline is 5500rpm's
while the auto lb9 redline is 5000 rpm's
Both Tach's should have the 7000 max rpm;s
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
