3.23 Gears in an 86?
Old Apr 26, 2006 | 08:49 PM
Bane's Avatar
I was looking through my RPO codes today and referencing them to the information given in the tech data section. Now my car has the GU5 option, which is rearend ratio of 3.23 and its in an automatic. Now, the tech data only says that auto's came with 2.73, but the 85's had an automatic with 3.23, is there any possibilitythat this rearend is an 85 in my 86? or was there the GU5 option in '86?
Old Apr 26, 2006 | 10:12 PM
tagta189's Avatar
I have an 86 iroc and mine has a 3.23 rearend ratio.I think you should be turning around 2700 rpm or so at 65mph.
Old Apr 27, 2006 | 02:01 PM
87TAairlineyard's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
GU5 was available in 1986 as actual gears in the the performance axle option (I think G92), 2.73 gears are RPO code GU2. GU5 and G92 should both be on your rpo code sheet.
Old Apr 27, 2006 | 05:33 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Not sure about this, but G92 may not be on his sheet. G92 was introduced in 1987 as a performance option package for Camaros... Usually G92 included things like oil cooler also IIRC.
John
Old Apr 27, 2006 | 08:48 PM
Bane's Avatar
I would also imagine that the special axle option would entail posi and my car does not have posi.
Old May 1, 2006 | 01:05 PM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
No there is a seperate code for posi I think it is G80.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Numbah-1
Sep 12, 2015 08:57 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
