Grey Leather Door Panels
Old May 30, 2006 | 02:07 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Are these fairly common, or more on the rare side? I have a chance to scoop up a set for my TA, but cash is very tight at the moment so I am wondering how often they appear for sale? I did a quick search and didn't find any mentioned anywhere.
Thanks for your time and help.
Old Jun 6, 2006 | 02:32 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I have a set in my 92 Camaro that match my leather seats. I have not seen a lot of them.
Old Jun 6, 2006 | 07:54 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I guess I have to ask:
Are they the molded pieces with leather inserts or are they the flat cardboard ones with leather inserts?
The molded ones I would think would be worth snatching (get the arm rest brackets if you can.)
If they are the flat ones, you can easily replace the inserted area with leather. Would not stress about it. Especially if your panels are in good shape. Basically you remove the metal "L" piece and the top plastic door sil and then you can peal the old stuff out. using some 3M 90 spray adhesive you can put the leather in.
John
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
