are t-tops strong enough......????
Old Jun 6, 2006 | 11:29 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
as some of you may no, im trying to get my iroc lifted up so i can put some jack stands under it.. my question is, is the top of the car ( the t-top bar ) strong enough to hold while im lifting the car if the doors are off? or should i leave the doors on until the car is up??? i took the glass tops off just in case... thank again everyone....
Old Jun 6, 2006 | 11:33 AM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
well, its probably strong enough without the doors, but i personally wouldnt risk it...
Old Jun 6, 2006 | 11:35 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i was thinking just leave em on, then take em, then when i lower the ride, put them back on, prolly gonna be a PITA...
Old Jun 6, 2006 | 02:47 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Do you have access to an extended lift floor jack(lifts to 21" instead of 17" - and the bigger jacks go higher if you can rent one)?I use mine on my '83 and it helps in setting jacks stands under her.
I don't know if I'd risk lifting her by the roof braces.You could cause unseen flex.And T-top cars have a problem with flex in the "B" pillar area anyhow.And the doors are part of the frame structure.That's why they're braced so heavily.
Old Jun 6, 2006 | 03:07 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
nope, no access to that type of eqpt. just a hydraulic jk and jack stands... my gut feeling says to leave em on til i get her up then take em off and put them bk b4 i lower it, again , i bet its gonna be a PITA
Old Jun 8, 2006 | 04:37 PM
Birdman92's Avatar
Car: '92 Firebird
Engine: V6 for now
The Demo derby car builder/driver in me says just lift it because it wouldn't effect most cars, but with a third gen t-top I don't know. Those doors are as heavy as they are for a reason. As previously mentioned, the doors are part of the unibody structure. I would leave them on just to be safe, I have jacked a few cars up without doors, hood, or trunk lid, but never an f-body.
RS Reaper
Oct 17, 2018 07:52 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
m00n420
Sep 11, 2015 02:39 PM
