replacement of door hinge bushings
Old Jun 11, 2006 | 01:53 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
door hinge bushings worn pretty bad. not an expensive part but i think it's going to be a PITA to do. my stepfather (he has an 84 z28) thinks im going to have to remove my driver side ground effects to get to the pin. is there an easier way to do this job? how long should this take? and are there any special tools or advice on how to do this job. it's starting to irratate me, door hangs down and doesnt close properly.
Old Jun 11, 2006 | 03:18 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Good luck on the project, doing a simple search will give you all the info you need because this has been covered soooooooooo many times. This is a freebie give it a try, https://www.thirdgen.org/forums/body...hab-resto.html or this https://www.thirdgen.org/forums/body...=pins+bushings
Old Jun 11, 2006 | 05:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hmm, zip ties, vice, $5 pin.... Damn! That seems like it's worth trying for me.... I'm *******ish that way. If it fails, i'll be calling up Lon and getting the greasable kit, with a spring compressor tool.
Old Jun 11, 2006 | 05:43 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It worked for me
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
