3:27's without g92 code?
Old Jul 9, 2006 | 03:24 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
My 88 formula i believe has 3:27's in it but on the RPO tag there is no G92 code. The car spins about 2600-2700 RPM between 75 and 80mph. And when the car was stock it ran 14.7 in the quarter, i dont think it could have done that with 2.77's. does anyone have any ideas? The car only has 52k on it and i purchased it from the original owner completely stock.
Old Jul 9, 2006 | 04:17 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Check your axle tag. High rpms on the highway could be as simple as your torque converter clutch not working.
Old Jul 9, 2006 | 09:26 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Or your tac is not accurate. I ran a 14.8 bone stock with 2.77's, and I had traction problems. Easily could have been a 14.7.
Old Jul 9, 2006 | 10:13 PM
Mark 89Formula's Avatar
All 87-89 Formula 350s came with 3.27s stock. You couldn't get 2.77s. G92 does not appear on my invoice or SPID either, just G80 for limited slip. There's usually a tag on the rear axle secured by one of the nine differential cover bolts listing the axle ratio.
Old Jul 9, 2006 | 10:33 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If I'm not mistaken, G92 won't show up on a Firebird, only a Camaro.
Old Jul 9, 2006 | 11:53 PM
FormulaL98's Avatar
you guys were right. G92 is the code for camaros equipped with 3.27's. Firebirds used code GW6 to signify 3.27's. I checked out 3rdgenformula.net, theres a ton of good info there so check it out if you havent already.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
