1984 2.8L V6s: LL1 "CodeL" vs LC1 "Code1" ?
Car: 84 Firebird: F41, Pwr, Instr Pkg
Engine: LC1 (V6 2.8L, 280k mi)
Transmission: MD8 (700R4)
Axle/Gears: GU5 (3.23)
Nobody on the V6 forum seemed to know anything about this. THought I'd try posting here to see if the anyone has any insights into these two engine options... thanks
Any good insights or details as to differences (or how to recognize)
these two 2.8L V6s?
All I know or have gathered is (for 84 Firebird):
LC1 "Code1" 8.4:1, 107hp, 145 ft/lbs, R43CTS plugs
LL1 "CodeL" 8.9:1, 125hp, ??? ft/lbs, R42CTS plugs
They can be differentiated by the 8th digit on the VIN but beyond that,
don't know much about their differences, internally or externally...
Why the cooler plugs on the LL1 and would the LC1 benefit from the same plugs. E.g. would that be a better heat range perhaps for
the LC1 as well?
these two 2.8L V6s?
the LC1 as well?
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Well i think i have the LC1 in my 84', theres not too much power of course but i never heard of the other 2.8l before.
But i notice it has alot of power then most of the 2.8l's, so mabye i have an LL1?
But i notice it has alot of power then most of the 2.8l's, so mabye i have an LL1? Last edited by 84'Firebird; Aug 7, 2006 at 05:29 PM.
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
I'm not sure if this answers your question. There were two different 2.8L engines in 1984. One was the standard motor and the other was considered as a H.O. version. Higher compression...more horespower.
I had a 1984 S/E firebird a few years ago. I went to buy plugs for it and the tech asked if I had the standard or the H.O. version.
Just my .02 cents worth.
-bill
-bill
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
In 83’ Pontiac introduced the H.O. V6, (LL1) for the S/E. The low output V6 (LC1) was only available in the base firebird. They have different heads, among other things, so simply changing spark plugs won’t give you any change in power.
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Car: 1983 Trans Am
Engine: L69 5.0L HO
Originally Posted by tpi-hearse
aka both junk
The 4 firebirds I’ve had with V6’s worked rather well. They always started, even when I ran one of them without oil (side note: if you change your valve cover gaskets make sure the valve cover bolts are tight when you’re done), it got me home.
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
