15" wheels and performance suspension
Old Aug 20, 2006 | 09:57 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Could you ever get a Trans Am with 15" wheels and WS6?
I have come across 2 1985 Trans Ams that claim performance suspesion but have 15" rims. I suspect its just the F41 but am not sure (cars in question are both 1985)
Old Aug 21, 2006 | 03:01 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
trans am ws6 and 15" sure common as dirt, i stripped one, an 85, was 305 and 700r4 and posi disc 10 bolt
common as hell
same with all the earlier years at least, and in 82 83 84 too, nothing out of the ordinary
what makes you think 15" and WS6 never was together ? or did i read your post wrong ?
good luck
Old Aug 21, 2006 | 06:41 AM
avro206's Avatar
Car: 89 Formula
good luck
well I know at some point in the 80's that WS6 was an option on Trans Ams--friend has a 91 T/A with F41. Came with those 215/60/16 tires.
I just did not know WS6 was avabilble with 15" rims.
I have a Firebird Redbook and it gives conflicting info
Old Aug 22, 2006 | 11:49 AM
Guest
Guest
Posts: n/a
In 1985 (and up), the 16" wheels were part of the WS6 package and you couldnt get 15's with the WS6.
Old Aug 22, 2006 | 12:25 PM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
In 85 there was a performance suspension that was optional and not the WS6 option. I have it on mine. I think though in 86 maybe just a bit later this option later became standard and since in 85 this option got the Performance Suspension badge it also got it when it was standard equipment. Not sure if this was standard for the basic birds, but im pertty sure it was for Trans ams after 85.
This could also explain it.
Old Aug 22, 2006 | 05:50 PM
Drew's Avatar
First off, the Firebird Redbook is more accurate as toilet paper.
Second, F41, FE2, etc are all considered 'performance suspension'.
All WS6 cars are 'performance suspension', not all 'performance suspension' cars have WS6.
Old Aug 22, 2006 | 07:27 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
ws6 had 16'' rims with 245\50\16s..not 215\60\16 and performance suspension dues not mean it is a ws6 car
Old Aug 22, 2006 | 07:28 PM
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Isn't this what i just said?
Old Aug 22, 2006 | 07:34 PM
tpi-hearse's Avatar
yes close but you didn't correct him about the tire size
Old Aug 22, 2006 | 07:35 PM
avro206's Avatar
Car: 89 Formula
okay I see what your saying. Aren't all FE2 cars WS6? I have seen both on the same car.
Old Aug 26, 2006 | 04:09 PM
Drew's Avatar
WS6 is a merchandising code for a option package. FE2 designates the suspension level.
WS6 has always been a package consisting of performance options, mostly suspension, but FE2 is swaybars and springs. FE2 is the one to look for if you're concerned about a stiff suspension.
Vintageracer
Jan 10, 2020 05:33 PM
cam-mike
Aug 24, 2015 07:23 AM
Randomtask2
Aug 13, 2015 01:57 AM
