Shift Indicator Plate - what year/model is this from?
Old Aug 28, 2006 | 12:01 PM
86TARecaro's Avatar
Car: 1986 Trans AM Recaro Option
This is a Shift Indicator Plate that I thought would fit my 86 TA w/ Auto 700R4, but not so, The boot for this plate is attached to a white plastic plate with 3 bosses that sit in the top of indicator plate.
Anyone able to identify the year/ model that used this?
Attached Thumbnails Shift Indicator Plate - what year/model is this from?-plate2.jpg
Old Aug 28, 2006 | 12:37 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yeah thats no where near the same as for a TG f body hmm
im trying to think of what other 80s models of GM had automatic overdrive, either 700r4 or 2004r, but im unsure, could also be olds pontiac buick etc with the 2004r
hmm
good luck
Old Aug 28, 2006 | 01:32 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
That's from a '91-'92 Firebird. Both styles are interchangeable but you have to change the entire shifter plate. The piece that you have won't help you.
Old Aug 28, 2006 | 09:55 PM
86TARecaro's Avatar
shift indicator
Thanks for the info. Will this also work on 91-92 Automatic Trans AM/ Formula & GTA ?
Old Aug 28, 2006 | 10:38 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
As long as the entire shifterplate is a '91-'92 model.... yes.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
tonys91rs
Sep 2, 2015 07:07 PM
