How Rare is this? and how much is it worth?
Old Sep 2, 2006 | 01:35 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I went to the junkyard yesterday and I picked this up from a early berlinetta, it had a digital cluster but It was too much effort to remove so I just left it there and took the console, since it was something I never seen before... so how rare are these? and is it worth something?
Old Sep 2, 2006 | 02:32 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
That's one unusual console you have there.
I've been to lots of junkyards and I've seen quite a few berlinettas in my time, but I have never seen a console like that before.
I wonder how many were built? that tape deck is probably the most odd part about it.
Old Sep 2, 2006 | 02:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Every Berlinetta had it.
Old Sep 2, 2006 | 08:01 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
during what years???
Old Sep 2, 2006 | 08:13 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Old Sep 2, 2006 | 09:07 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Correct, that's the "star wars" cluster and console. The all push button delco ETR radio was I think the first one in an Fbody, as Pontiac's UT4 stereo did not appear until 1985 in the Firebird. Certainly worth something to any one restoring a berlinetta from those years.
Old Sep 2, 2006 | 11:26 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Not every Berlinetta, only the ones with the digital dash, there were a few Berlinetta's that had standard gauges. I looked a buying a V6 Berlinetta a few years ago that had standard gauges.
Old Sep 2, 2006 | 11:30 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I used to have an 84 berly, had that console in it.. looked neat but was a PITA.
It had the digital cluster as well.
Old Sep 2, 2006 | 11:34 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
Not mine
Old Sep 3, 2006 | 01:31 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
so how much is this worth roughly? Myself I have never ever seen anything like it... I was thinking of cutting the squares out and removing all the hardware from that tape deck... but my dashboard is different than that of the berlinettas.. so I decided not to install this.
Old Sep 5, 2006 | 12:13 PM
ADV1's Avatar
It would be worth more if you have the brains for the stereo that were in the console... Hopefully you grabbed that!
On Ebay I've seen a "Nice" radio go for around $50-60 but add in the console and I'd say you're in the $100-150 range of things...
Old Sep 5, 2006 | 01:00 PM
onebad400's Avatar
what junk yard did you get the console at and do you have a phone number? the reason why i ask is because i have a 85 that have the digital gauges and i need the plug that screw into the tranny for the speedometer and the wiring plug and wires that conncet to it.
Old Sep 5, 2006 | 09:00 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
If the stereo/tape player works, there can be quite a demand for it. I've known a few people who have had that system but it is either damaged or simply doesn't work and they wanted to restore it. But trying to find such unique parts (that work) is becoming very difficult.
Good find.
Old Sep 10, 2006 | 05:33 PM
Drew's Avatar
It's an 84-86 Berlinetta console, before 84 the Berlinetta used the standard Camaro dash and console. It might be worth something to a Berlinetta owner, but you'd have to find the right buyer. Ebay would be your best bet to unload it.
Old Sep 12, 2006 | 11:59 AM
Abubaca's Avatar
My Ex back in high school had an 85 with that dash/console set-up. Pretty neat looking but it was a PITA too.
......I bet you could go years and not get more than a few bucks for it. Then out of the blue you could find someone doing a resto and they'd probably pay hundreds for it. It's a crapshoot.
Linson
Oct 24, 2025 02:00 PM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
sjorgens
Oct 1, 2015 07:54 PM
