RPO question.
RPO question.
First, I have a lot of RPO numbers from my 91 Z28's console that I haven't found references for.
Second, is there a cross reference somewhere so that the number of '91 coupes (not the t-bar) can be verified with the RPO G92 package? So far, I haven't found anything so detailed.
Thanks for any assistance you can give, Edward.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
You could post the RPO's you can't find here and someone should be able to help you.Some of the codes on the the SP sheet are plant codes and you might not find them.There are several RPO decoders on the web and some don't recognize all codes(and you'll even get some that don't agree with each other.Also try Welcome To Camarosource.ca* - Internet's Largest Most Complete Camaro Resource Site and try the RPO decoder there.
As for the break down for T-top/non T-top cars with RPO G92 I don't know if you'll get a specific production break down.The "Camaro Whitebook",which isn't 100% all the time, gives total production for '91 RPO G92 at 6,813 cars.It only states that it was optional on coupes and not on convertibles.
Hope this helps. Isaac
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Just wondering since yours is a 91 it should be in the rear hatch compartment not in the center console maybe thats why, unless thats what you meant
I haven't found my build sheet yet. There is a list of RPO numbers listed in on the interior of the console so I've been checking those. I'm guessing, at this point, that if I find the build sheet that it will reflect the same numbers in the console. Anyone else have a build sheet that listed something different?
ZZ3Astro
Aug 13, 2019 12:57 AM
