Are all TPI runners the same?
Old Sep 28, 2006 | 08:06 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
I have heard that 85-88 runners are different than 89-92 runners ... is this accurate? I need to replace mine and I have found a set but it is off of an 86. Thanks!
Old Sep 29, 2006 | 04:29 PM
cdartz's Avatar
Only the driver side is different. The later ones do not have the hole in them that the cold start injector would fit through, because from 89 up the cars no longer had the injector.
Old Oct 1, 2006 | 02:43 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
Another cosmetic difference is the finish on the runner itself. The Corvette runners and the LATE 92 F-car runners both have the rough wrinkle finish, whereas all the other thirdgens have the smooth finish. My 92 Z28 had the wrinkle finish because it was built in july of 92. Personally I like the rough finish better than the smooth finish, it matches the rest of the TPI finish very well.
Old Oct 3, 2006 | 12:00 AM
gcgarner's Avatar
Mine was built in April 92 and has the smooth runners. Strange.
fisherbody86 ... I think you can safely say that you have one of THE LAST third gens ever produced. July 92!!!! Wow.
Old Oct 3, 2006 | 08:45 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
My 87 has on it runners that do not have the cold start injector. When I first put them on I was baffled to why the car would not run, it would start and immediately die. What was happening is not only is the drivers side small tube for the COld start injector it is also the plumbing for the IAC.
Once I figured it out I took my Throttle body and milled out the center section like a 89-92 style Throttle body. Now I can run either set of runners.
I am not sure if the intake base on the 89-92's have the provision to actually install the drivers side runners from the 85-88 style. It would not surprise me either way, as I believe all they did was cover the hole in the base because IIRC there is a bolt that goes in the area anyways. I have an 89 Intake in the back I can peek at if I get time.
l8r
John
Old Oct 3, 2006 | 05:58 PM
cdartz's Avatar
Nope I found that out the hard way years ago trying to run an '89 base with an '86 runner and plenum setup. No hole in the base.
Old Oct 8, 2006 | 05:13 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I thought all TPI throttle bodies were the same. I had no idea that the small tube was for the IAC. I thought all IAC passages were strictly in the Throttle body. Learn something new every day.
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
