WS6 VIN
Old Dec 20, 2006 | 03:14 PM
hughes7000's Avatar
WS6 VIN
I have a 1984 Trans Am and was wondering if there are any characters in the VIN# that will tell me if it has the WS6 package?
Old Dec 20, 2006 | 06:07 PM
Drew's Avatar
The VIN will tell you where it was made, what engine it had, blah blah blah, it won't tell you if the car had WS6. Look on the top of the radiator support for a stamped plate with various codes. If it was a WS6 car, I'd expect the code WS6 to be stamped there.
Old Dec 20, 2006 | 11:10 PM
87TAairlineyard's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
If not under the hood, it should be on the build sticker which I think on 84s was located in the rear trunk area, probably in the little "glove box" on the driver side rear. WS6 shuld be listed there. Another hint is if you look at your driver side door jamb, the tire sticker (if its still there) will show 15 inch wheels if its a WS6. WS6 from 82-84 had 15 inch wheels, while 14s were standard. In 1985, 15 inch wheels were made and standard and 16 inch wheels reserved for the WS6 package.
Old Dec 21, 2006 | 08:09 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
1) I am pretty sure that my 83 Trans Am is not WS6, but it had the 15" tires.
2) THe SPID sheet was placed in the center console from its inceptin in 84 thru about mid 1991, when it was relocated to the rear area in the car, which in my opinion is a better place for it. Why they stick it on a non-permanent part of the car is beyond me. They should have placed it on some sheet metal and not on some removable plastic piece.
John
Old Dec 27, 2006 | 08:15 AM
hughes7000's Avatar
Thanks all for helping me out.
Old Jan 17, 2007 | 11:11 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the WS code was not always on the body trim tag
it was funny sometimes like this
youll have to go by the vin code to knwo if its a t/a or s/e or neither, but it wont help you with determing if its a WS6,
to know that if it doesnt have a WS code on the tag and doesnt have a buildsheet or anything else you will have to assume its a WS6 if it has the right brake system and sway bar diameters and steering box and springs and so on, the right ones for a WS6 for that particular year, as not all years of WS6 parts/equipment were identical in size and such
good luck
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
dbrochard
Sep 7, 2015 09:41 AM
