tire coding
Old Jan 9, 2007 | 10:47 PM
Firebird1984's Avatar
Car: 1984 Firebird S/E
Engine: 350 V8, 4 barrel carb
Transmission: 700 R4 automatic overdrive
tire coding
I have a 1984 Firebird S/E model that according to the build sheet originally had 215/65R15 tires on it from the factory. Someone swapped to 215/60R15's and that is a bit shorter tire. I am planning to go to the 235/60/15 to regain the original height of 26 inches.
Now that I look at the build sheet, the size stated is 215/65R15 and immediately after that it has the following letters... "WLTR" I am guessing that it means that it originally had raised White Letter tires on it from the factory? If so, I am going to find some and put them on so it looks like it originally did from the factory. Am I interpreting this correctly? Thanks!
Brad
Old Jan 10, 2007 | 10:34 AM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
Yes you are. They came with Goodyear eagle gts on them with the raised white lettering. I believe Coker tire now reproduces them or will be in the near future.
Old Jan 10, 2007 | 09:25 PM
Thanks for the reply! I appreciate the help and especially the identification of the original tire make and type! I'm going to contact Coker tire and see what they have. If nothing else, I'll go with the BF Goodrich Radial TA's as I can get them easily and inexpensively right now. I would like to at least see what the orignal type would cost first. Thanks again!
Brad
Old Jan 15, 2007 | 04:09 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Can't go wrong with BFG.
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
