RPO Help Request
Old May 17, 2007 | 12:31 AM
StompaStang's Avatar
Car: 1 of 3 Camaro's
Engine: 4 vehicles all V8's
Transmission: Both AM and FM
RPO Help Request
Hey everyone,
Okay been trolling around for a couple of weeks and trying to read up before i asked to many questions however.......
I am having trouble with a few RPO codes.
Here's what I have so far:
AC3 6 WAY POWER SEAT,DRIVER SIDE
AJ3 Restraint system,Front seat,Inflatable,Driver
AM9 SEAT BACK,SPLIT FOLDING REAR
AR9 SEAT ASM, FRONT BUCKET RECLINE
AU3 Power Door Locks
A31 Power Windows
A90 Power Hatch Release
B18 ORNAMENTATION INTERIOR
B34 Floor Mats
B35 Floor Mats
B84 Body Side Moldings
CC1 Roof Panels Removable Glass
C49 Rear Window Defogger
C60 Air Conditioning
DC4 Mirror with dual reading lamps
DG7 Mirrors electric twin remote
D34 MIRROR VISOR VANITY
D42 Cover,Rear Compartment Cargo
D7C GEAR , SPEEDO DRIVEN
D8N Sensor,Vehicle speed
D81 SPOILER , RR, AERO WING
E5Z Speedometer adaptor(delete)
E9Z SPEEDO KEY DELETE
FE2 SUSPESION SYSTEM,TOURING&HANDLING
GU2 Axle,Rear 2.73 Ratio
G80 Rear Axel limited slip
IPC Trim,Interior design
J41 Brake System,Power front Disc,Rear Drum,Cast Iron
K34 SPEED CONTROL WITH RESUME
K68 GENERATOR 105 AMP
LB9 Engine,305ci,190hp,V8
MD8 TRANSMISSION 700R4
MX0 TRANSMISSION AUTO WITH OD
NA5 EMISSION SYS.FEDERAL REQUIREMENT
NP5 WHEEL STEERING LEATHER WRAPPED
N65 Wheel & Tire,Spacer Saver,Steel
N96 WHEELS ALUMINIUM 16 INCH
QLC TIRES P245/50ZR16
R6V CONTROL , SALES ITEM NO. 21R8T
R8T CONTROL , SALES ITEM NO. 69
T96 LAMPS FRONT FOG
UB3 Cluster,Instruments,Oil,Cool Temp,Volts,Trip Odometer,Tachometer
UN6 RADIO AM/FM STEREO SEEK/SCAN AUTO REV MUSIC SEARCH
UQ1 Radio Provisions for Stereo
U79 SPEAKER SYSTEM 4", DUAL FRT COAX, DUAL EXT RGE PKG SHELF
VAN Van NUYS ASSEMBLY PLANT
VK3 MOUNTING FRONT LICENSE PLATE
V73 VEHICLE STATEMENT, U.S./CANADA
Z28 PERFORMANCE PACKAGE, SPECIAL
1AY Dealer Ordered Vehicle
ISD OPTION PACKAGE 04
17P Wheel Cover, Silver
24Q MOLDING COLOR , OPAL BLUE
6ZW SPRING,COMPUTER SELECTED,FRONT RIGHT HAND
7ZW SPRING,COMPUTER SELECTED,FRONT,LEFT HAND
8NL Spring,Computor Selected,Rear,Lefthand
82C Grey custom cloth interior
82I Interior Trim,Medium Dark Gray
829 Seat belt Color,Medium Dark Gray
9NL Spring,Computor Slected,Rear,Righthand
98U Ultra Blue Exterior
Any assistance would be greatly appreciated.
Old May 17, 2007 | 08:57 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: RPO Help Request
First welcome to TGO if you haven't been already.Sounds like you have a love of Camaros in general and a very nice '91 z28 in particular.
The RPOs I can tell you offhand are;
82C - Grey custom cloth interior
98U - Ultra Blue exterior
The others I don't have a list for offhand.I take the SPID sheet is either missing or the wrong one is in your car.Being a '91 you can go to a Chevrolet,or any GM,parts Dept and they can run your VIN and give you a printout of all the option codes.To decipher them you can use the RPO decoder on here or these sites;
http://www.camarosource.ca/main_new_...new_layout.htm
http://www.team3rdgen.com/modules.php?name=RPO_Decoder
Old May 17, 2007 | 12:30 PM
Yea I tried the site with the listing but could not a majority of the numbers.
The sticker isnt missing I found it right where it was supposed to be (left rear cargo bin)
I just couldnt find a majority of the numbers on the site.
P.S.
Thanks for the welcome.
Old May 17, 2007 | 07:35 PM
coolram62's Avatar
Engine: LU5 305 CFI
You are most welcome.Did you try the second site.It gives a drop down list for RPO's.One thing you will find is that some sites decoders don't come up with the same results.Hope the below helps.
AJ3 - Restraint system,Front seat,Inflatable,Driver
D8N - Sensor,Vehicle speed(Also could the D81 be a D8I)
E5Z - Speedometer adaptor(delete)
GU2 - Axle,Rear 2.73 Ratio
IPC - Trim,Interior design
J41 - Brake System,Power,front Disc,Rear Drum,Cast Iron
N65 - Wheel & Tire,Spacer Saver,Steel
UB3 - Cluster,Instruments,Oil,Cool Temp,Volts,Trip Odometer,Tachometer
UQ1 - Radio Provisions for Stereo
1AY - Dealer Ordered Vehicle
17P - Could be for wheel color
8NL - Spring,Computor Selected,Rear,Lefthand
82I - Interior Trim,Medium Dark Gray
829 - Seat belt Color,Medium Dark Gray
9NL - Spring,Computor Slected,Rear,Righthand
Old May 17, 2007 | 08:37 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
D7C GEAR , SPEEDO DRIVEN (D7C)D81 SPOILER , "RR, AERO WING"UN6 RADIO , "AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH"U79 SPEAKER SYSTEM , "4, DUAL FRT COAX, DUAL EXT RGE PKG SHELF"24Q MOLDING COLOR , OPAL BLUE (97)R6V CONTROL , SALES ITEM NO. 21R8T CONTROL , SALES ITEM NO. 69
Old May 18, 2007 | 05:58 PM
Wow everyone, thanks so much for the help,
Only one item unaccounted for any further assistance would be greatly appreciated.
Also if any of you wouldnt mind taking the time its all looks good to me but maybe your eagle eyes will catch something I missed.
Old May 18, 2007 | 08:46 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
17P-Wheel Cover, Silver
1992Z28!
Nov 19, 2015 07:33 AM
AussieZ28
Sep 30, 2015 03:36 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
327IROC85
Sep 23, 2015 12:11 AM
funkyTA
Sep 10, 2015 06:38 PM
