Centerbolt Valve Covers on an '85
Old Aug 3, 2007 | 04:29 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Like the title already stated, my car is a 1985 Camaro Z28 with an LB9. I never really took particular notice to this but I realized that my engine has center bolt valve covers. Now AFAIK, center bolts only came on 87+ engines correct? Is it possible to swap center bolt/ perimeter bolt valve covers at will on these heads? One other thing I noticed is that my engine and heads have been painted red. If I'm not mistaken, didn't the engine come from the factory painted blue?
Even if I do have different heads I know it's not making me go any faster, 15.5 @ 87 in the 1/4.
Old Aug 3, 2007 | 08:58 PM
Stephen's Avatar
Car: 87 GTA
Re: Centerbolt Valve Covers on an '85
I'd say you have newer style heads.The valve covers are not swappable. Oh, they'll physically fit, but you'll have no way to bolt them down.
Unless you get some aftermarket heads, that have both style bolt holes.
OR, you can get adapters, to bolt older valve covers, to the newer heads.
Old Aug 4, 2007 | 04:07 AM
DBLTKE's Avatar
Engine: LB9, LB9
I'll see if I can get the casting number off of them so I can check out what they really are. Is there any difference in the LB9 heads from '85 to '87+ besides the location of the valve cover bolts?
Old Aug 4, 2007 | 05:53 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Also check the front pad of the block on the passenger side.The engine code(3 letters usually)build date and the sequential part of the VIN is stamped there(will match your car's VIN if original - that is if the block hasn't been decked).
Old Aug 4, 2007 | 08:21 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Ive never heard of one of these engines being painted blue from the factory. I think they were either painted black or left with their natural finish. Anybody know for sure.
Old Aug 4, 2007 | 08:47 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
mine was rust color when i pulled it out
Old Aug 4, 2007 | 01:44 PM
Guest
Guest
Posts: n/a
Gm painted them black.
Old Aug 4, 2007 | 03:04 PM
DBLTKE's Avatar
Engine: LB9, LB9
well I do remember reading somewhere that pre 82 engines were painted orange, 82-92 engine were painted blue, and 93+ engine were painted black. but of course I may be mistaken. I'll see if I can find the casting numbers and engine code today. I'm doing an engine swap pretty soon so if I can't get these now I'll at least get them later.
Old Aug 4, 2007 | 03:38 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
1982 was the only year for thirdgens for the engine to be painted Chevy Blue. From 1983 on...they are GM Black. And 1986 was the year for the appearance of centerbolt valve covers, on the Corvette Convertible. 1987 for everything else
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
