IROC VIN
Old Aug 17, 2007 | 09:03 AM
adamhon's Avatar
Car: '89 Chevy Camaro RS
Engine: 305 V8
Transmission: Automatic
IROC VIN
Hey I need help fast!!!! I am looking at buying a '89 IROC this afternoon, but the VIN plate is gone and it has a VIN issused by the State of Indiana I am guessing. I want to make sure it is a real IROC, I have looked it over and can't find anything that doesn't match up with what an IROC should have but I am not a professional. I did not see an RPO sheet, is there something else I can look at or is there somewhere else where the VIN is posted? Thanks
Old Aug 17, 2007 | 11:28 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: IROC VIN
Welcome to TGO first.
I would check with the state,if you haven't already,and make sure the car and title are clean.There's another member going thru a bad VIN situation now.On using the VIN the only way to tell is if the eighth digit(GM's VIN sequence) or engine desigination is F(LB9 305) or 8(L98/B2L 350).The 350 came only with an auto the TPI 305 could have auto or manual.If the tire decal is still on the driver's door and indicates 16" wheels that's another way.The stabilizer bar size and the presence of a "wonderbar"-front steering brace is another way.Check the Tech section of TGO and also thise site
http://www.camarosource.ca/main_new_...new_layout.htm
for more info.Good luck and be careful.
Old Aug 17, 2007 | 09:54 PM
adamhon's Avatar
Engine: 305 V8
Re: IROC VIN
Thanks, found the VIN in the compartment on the left in the trunk, it was on the fendor, it is a true IROC with the 350 and automatic. I Bought it.
Old Aug 18, 2007 | 08:45 AM
coolram62's Avatar
Engine: LU5 305 CFI
Re: IROC VIN
Congratulations on a nice find and good luck with the VIN being correct.Please post some pics when you get a chance.
tom1985
Apr 19, 2016 07:55 AM
dbrochard
Aug 30, 2015 05:56 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
