Help, Window problems
Old Oct 12, 2007 | 12:41 PM
adamhon's Avatar
Car: '89 Chevy Camaro RS
Engine: 305 V8
Transmission: Automatic
The drivers door window on my '89 IROC comes up all the way but it is not going into the seal, it comes up just out side of the groove for it, which gives me wind noise and airflow. I have not taken the panel off of the door to look at it better, but I was just wondering if someone has fixed this problem before and if they had any tips. Thanks.
Old Oct 13, 2007 | 07:00 PM
Gramps's Avatar
Car: 87 Camaro IROC
Re: Help, Window problems
somebody move this thread so i can post in it.
Old Oct 13, 2007 | 09:23 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Is it possible the weather stripping is shot? If not, you need to remove the door panel and adjust the window regulator up.
Old Oct 15, 2007 | 08:48 AM
adamhon's Avatar
Engine: 305 V8
I don't think it is the weather stripping, it seems like my window is loose. When I shut the door from outside and push on the window it shuts right, but when I try and roll it up from inside, I pull it in as long as I can and sometimes it will go in the weather stripping but most times it comes up half out of the weather stripping. Where do I need to post this so Gramps can reply?
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
neekolzun
Aug 24, 2015 04:59 PM
