RPO Codes
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
RPO Codes
I was hoping someone might be able to tell me what these RPO codes are, the decoder comes up with either a error or ???
B3W B9K C48 or C4B D7G GC5 GC6 N0D YT9
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: RPO Codes
Welcome to TGO if you haven't been already.
NOD - Assembly Plant,Norwood,Ohio
YT9 - Option Package,Fisher Furnished Parts
The others I haven't found yet.Could the C48 be C49(rear window defroster)?The B and G codes could be the codes for front and rear springs(just a guess though).
Re: RPO Codes
After the C4B or C48 there is a C49 which the decoder did bring up a defross
Re: RPO Codes
My RPO sticker was scraped by some one is there anywhere else to find it in the car besides the center and the locked pannel ing the trunk. My car is a 1987 iroc z28 limited edition with a wing i have never seen. With out the rpo codes does my car not stand up to its name or is it worthless. Any help would be greatful thx.
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: RPO Codes
B3W - Advanced Price Sheet - Processing Option
B9K - Ornamentation B/S MLDG -Reapply to RR Door only
C48 - Heater Delete
GC5 - Right Rear Fender Height Adjustment
GC6 - Left Rear Fender Height Adjustment
This is what I found, Hope that helps!
C48 - Heater Delete
Re: RPO Codes
Thanks everyone for you help, I even bought the Camaro Whitebook and it did not have these codes listed
Car: 1986 Iroc z
Engine: 350 tpi
Re: RPO Codes
ok here we go. this is my first ever post on this site. i have a few questions about RPO codes and the like. This is what i have. 1986 Camaro I roc-z. it has a Chevy 350 corvette TPI motor in it.i know that very few 350s were made in this year but VERY hard to come by. so i dont know if this is original or not. ive searched everywhere and this motor did not match up to the VIN or rpo codes that i can see of. i need help with a few codes
b3w
b9k
c4b
d6f
e7z
gc5
yt9
1ay
i see that its a true iroc. but the wheels are not the 16 inch rims they are 15s so someone took the original wheels somewhere. i paid 150.00 for the car. it runs and drives like a champ. it needs some TLC. can anyone help me here? i would appreciate it very much.
b3w
b9k
c4b
d6f
e7z
gc5
yt9
1ay
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: RPO Codes
B3W, B9K, C4B, and GC5 are in the above posts.
YT9 - Reinforced Doors
1AY - Stock Order Processing (Replaced by SCM circa 2001), not sure why it says 2001, but thats what 1AY comes up as.
Re: RPO Codes
According to the Camaro White Book, their was only 74 86 Camaro with 350and none were sold, they were used for testing, more likely it is a 305 or someone put the 350 in it
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: RPO Codes
According to records here and on other sites, they only made 50 Irocs with 350's (74 or 50, either way very few) and none were sold to the public. Also none were Corvette 350's (they were never put in a Camaro).
Here's a quote from the Thridgen tech database . . .
In otherwords, if that's the engine you have, it's not original.
It's rumored that records also show that 50 1986 350 (5.7) IROC's were built. These cars were built primarily for testing and were the ones we saw tested by the automotive press late in 1986. These 350 IROC's (being 1986's) had the externally mounted third brake light on the hatch glass and the pre-1987 head/edge mounted valve cover design. The 350 in the IROC-Z differed from the Corvette 350 TPI in that the IROC-Z 350 TPI had the regular Camaro valve covers, iron heads, (instead of aluminum) and the iron IROC-Z exhaust manifolds. At the last minute it was decided that the 1986 350 IROC would not be available. Fortunately they decided to start production of the 350 IROC in 1987.
Car: 1986 Iroc z
Engine: 350 tpi
Re: RPO Codes
Yes i didnt think so but none the less its fast. although i havent verified the numbers on the block itself that will telll the truth. whoever had it before me had put some work into it. Chrome valve covers. accel ignition distibuter and wires etc. not saying that makes it any faster but it helps. Thank you for the input. ill start restoring the rest of her. anyone have 16 x 8 rims for sale??
Axle/Gears: 3.08
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: RPO Codes
Can anyone tell me what these codes are...they came up as an error on the decoder.
R7F
X05
Z31
19P
R7F
X05
Z31
19P
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: RPO Codes
R7F - Control sales item 31
X05 - Sales processing option 14
Z31 - Advance Price Sheet
Don't know 19P
Don't know 19P
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: RPO Codes
Not meaning to jack your post, but where are the RPO codes? Is there a way to access the build sheet online or something like that, by the VIN? I think i found about 1/4 of my build sheet, thanks alot.
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: RPO Codes
I found my RPO Codes in the storage compartment in the hatch area. I believe they can also be found in the center console.
If yours are missing like alot of them are, I think you can take your VIN to a dealer and they can tell you what your RPO codes are supposed to be, now I may be wrong about that, but thats what I've heard you can do.
Re: RPO Codes
This is for 1986 iroc 350. RPO's
D6F is Gear, speedometer driven
E7Z is trans, speedometer gear related, key (speedometer delete)
1AY is stock orders processing option (dealer ordered car)
I'm trying to fine out what RPO Z5V is on my 1985 1C5 "California" IROCZ. Or if anyone else has this on an 85 Camaro?
This is for 89 transam*pearl.
RPO 19P is for 16" inch black crosslace wheels W/ Locking Package (Pontiac)
I'm looking for RPO Z5V. This next one is for 572_RAT
RPO D7G is Gear, Speedometer Driven
Last edited by yo soy el warg; Dec 16, 2007 at 10:16 AM. Reason: Automerged Doublepost
Car: 1986 Iroc z
Engine: 350 tpi
Re: RPO Codes
THANK YOU yo soy el warg!!! i appreciate the info..
Car: 92 Z28 / 66 Biscayne
Engine: 355 / 427
Transmission: T5 / M22
Axle/Gears: 3.42 Posi / 3.73 Posi
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: RPO Codes
19P = Black Wheel
Car: 1986 Iroc z
Engine: 350 tpi
Re: RPO Codes
ok so i got a new IROC.. well new to me anyway. still need help with RPO codes. ao1,e7z,1az,1hv can you help me?? the RPO decoder has no idea. thanks alot. i now have a 1986, a 1987 (with 65,000 original miles) and a wrecked 1989 Iroc. I think this is habit forming. thanks
Engine: LU5 305 CFI
Re: RPO Codes
This is what I've found so far.Hope it helps.
A01 - Windows,Tinted,All Shaded,W/S
E7Z - Key,Speedometer (Delete)
1AZ - Customer Ordered Vehicle
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: RPO Codes
Re: RPO Codes
You can call 1-800-222-1020 for a restoration kit, I believe the info, meaning full specs for your car is free.
Car: 1992 Camaro RC B4C
Transmission: M5
Re: RPO Codes
Hello, Just recently purchased a 92 B4C. I was checking the the RPO codes. There were a few that came up error in the decoder. I read through the threads but was unable to locate the codes. The codes are as follows;
AAT
B9D
C8E
C8G
C8M
EGW
FLT
IPB
PZB
R6D
R9W
VQ1
1AA
1SZ
any help would be greatly appreciated. Also does anyone know if the B4C VIN list was ever completed and posted anywhere. Thanks K-9 N Ks.
AAT
B9D
C8E
C8G
C8M
EGW
FLT
IPB
PZB
R6D
R9W
VQ1
1AA
1SZ
Car: 1989 Trans Am
Engine: 5.7 Carbed 1970 Camaro SS Block
Axle/Gears: 2.73, becoming 3.42 Posi
Re: RPO Codes
I cant even get the RPO decoder to open for me....is there some trick to it or is it broken now? I see that others are opening it just fine apparently...
PDG
PDG
Re: RPO Codes
If you are speaking of the one on our website (as there are others found on the Internet), ours is not broken. It requires .NET framework to be installed on your system. Make sure that is installed on your computer because that isn't always the case.
Re: RPO Codes
Honestly if you cannot find it here on TGO then go to goolge or Yahoo and type "RPO" and then the RPO in the search...
I could not find an exact for all of these, the following are what would be in the group. If you ever look at RPO's they group them together, and usually you can decipher what they may be from others in that area. IE AAT did not exist in my Dec 1993 Book but AA3, AA4, AA9, AA7, AB1 all do and they are all for some sort of Window... It may be a fast down window motor, or for a Black painted edge, its really not clear
AAT - Paint Process - Two Tone Special
B9D - VEHICLE GM PROD WEEK 04
C8E - SEO COMPONENT 2 BLACK
C8G - SEO COMPONENT 3 WHITE
C8M - SEO COMPONENT 1 BLACK
EGW - FLEET PROGRAM "DELAYED WARNING"
FLT - Sales Processing Option
IPB - TRIM INTERIOR DESIGN (PB)
PZB - I doubt this... Fuel Tank, LH Rect... More likely something to do with a Wheel, possibly spare tire, or Wheel cover...
R6D - Control Sales Item # 04
R9W - Control Sales Item # 96
VQ1 - FLEET PROGRAM DEALER ASSISTANCE, WITH HOLDBACK
1AA - Sales Incentive - Retail Amenities - Delete
1SZ - DISCOUNT OPTION PACKAGE
John
John
