How to replace rear wing?
Old Feb 6, 2008 | 03:51 PM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
Does anybody out there know how to take off rear spoiler of a 1991 Formula. Some poppped my passneger side by the window and cracked the bottom piece.
Andrew
Do not bypass language filters and fill in with "***". This is a violation of TGO rules! Scott
Old Feb 6, 2008 | 04:01 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: How to replace rear wing?
pop the hatch, remove the cover panel, remove 4 10MM bolts IIRC, slide it foward and lift up...sound about right?...either that or slide back but i'm pretty sure it's slide foward.
It's fiberglass so it should be able to fix it. Not all that easy but i think it can be done.
Old Feb 6, 2008 | 05:29 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
That pretty much covers it. I believe it is forward.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
