Did the LU5 have flat tops?
Old Mar 7, 2008 | 03:51 PM
CamaroLover09's Avatar
Car: 1983 Z28
Engine: 305 LU5 converted to carb
Transmission: built/updated 700r4
Axle/Gears: Open 3.23
I'm trying to find out if my 83 Z28 has flat tops or not. I haven't torn it down that far before and I wouldn't know what to look for anyway. I was looking at the tech articles and I noticed that the LU5 and L69s have the same compression ratio. It's my understanding that the L69 has higher compression because of flat tops. So is it safe to assume that my engine has flat tops as well?
Old Mar 7, 2008 | 04:20 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Did the LU5 have flat tops?
IIRC the replacement Part numbers for the long block less the intake was the same for both the LU5 and the L69... So the Heads, Block, Crank, Pistons, crank, & believe cam were all the same.
The LG4 had different heads & I think different pistons.
JOhn
Old Mar 16, 2008 | 10:01 PM
PowerHour84's Avatar
Car: 1984 Z28 Camaro
Engine: 305 -> 383 Stroker
Transmission: T5 -> T56
Axle/Gears: 3.73 Posi
I believe the LG4 were Dished pistons
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
TheExaminer
Sep 6, 2015 11:40 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
