Factory Shock color
Car: 90 RS
Axle/Gears: 2.77
Factory Shock color
I was just wondering what color the factory shocks and struts were. Did it very between suspension options?
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: Factory Shock color
Mine were white. However, I have an 83 z28, so who knows if the color changed as the generation got older.
Cheers!!!
Cheers!!!
Axle/Gears: 9-bolt/3.45
All of mine had black shocks and struts from the factory, so I'd think all thirdgens would've originally received black ones as the standard product.
Exceptions were(but might not be limited to): yellow Delco/Bilstein shocks(on IROC-Zs); and later, orange Delco/deCarbon shocks(though I'm not sure if these ever came on thirdgens).
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Mine are also black but i have a 91RS. The guy who installed my rear end also put on the stock shocks for an 87 Formula and they are also black.
Car: 90 RS
Axle/Gears: 2.77
So if it was a IROC then it had the bilstein's for sure or was this an option tied to the suspension. How would I check to see if mine had them?
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Black factory Delco struts and shocks on my '84 T/A.
IROCs came with factory installed Bilstein rear shocks. From what I've read the struts were still sourced from Delco but with "special" tuning. The three IROCs my friend has had seems to support this.
Normally it will say the company name on the shock. If there yellow thats a big indicator. Im not sure about on IROCS but my friends 84 vette has bilstein's and there yellow. You should also be able to run your RPOS and find out what suspension your car came with.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Both of my '86 IROC's still have the original yellow Bilstein rear shocks, and one of them still has the original front struts, which are black.
Car: 90 RS
Axle/Gears: 2.77
Do you have any pics? I am always trying to collect factory documentation, info, or pics. Years from now when people start restoring their 3rd gens (Dont laugh it will happen) things like this will come in handy.
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
I still have the originals on my 90' . . . Black AC Delco's.
I'm saving up for Bilstein's.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I can vouch for there originalilty as I knew the original owner. He never did any mods. And, I bought the car with only 27,000 miles on it.
My RPO's decode that besides the Z28 code (which all Iroc's had) but also the FE2 (Ride & Handling Suspension System) which was also likely part of every IrocZ/Z28 (I'd like to know if any differ). Part of the F-series RPO's dictates the type of suspension set-up. This is likely the code that related to the shocks and struts that are part of the IrocZ/Z28 package. Other FE# RPO's are for other types of handling like FE3 (Sport), FE1 (Soft), etc.
Car: 90 RS
Axle/Gears: 2.77
Sorry to beat this to death but was there any markings identifying them as Bilsteins? Any up close pics.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Mine were BLACK on my 89 Formula Vert BUT the WS6 came with GAS filled struts and shocks, I think the IROC came with Oil filled shocks and struts...
John
John
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
My 90 IROC came with black on the front and the back. It also came with an RS emblem on the driver's side rocker. I bought the car new.
Yes, they have a stripe around the bottom of the shock, and it says Bilstein. You can see it in DJP's pic. It's partially visible just above the brake disc, half covered by (what's probably) brake dust.
