Is this Camaro a 350?
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
http://cgi.ebay.com/ebaymotors/Chevr...spagenameZWDVW
I was looking at this car on Ebay and its 8th Vin Digit is an "H" which I thought designates a 350TPI, But if you look in the picture it shows a TBI/Carb looking motor....am I missing something?
Well, I guess the "H" must be a 305 carb...what letter designates the 350?
Last edited by Crusin' 1980's; May 8, 2008 at 06:19 PM. Reason: Automerged Doublepost
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
Re: Is this Camaro a 350?
From it's looks the mileage is believable. Very clean sharp ride. Not highly optioned and with a 165-hp 5.0. Odd they don't provide any details.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
In 1987 you could get a Camaro Vert in Two flavors 1) LB9/M5 or 2) LG4/A4. To my knowledge there were no other combos... No V6 cars, No LB9/A4, No LG4/A4 cars and obviously no "Authorized" L98 cars.
John
John
Car: 1985 iroc
Engine: 305 H.O.
Transmission: 5speed
Axle/Gears: 3:73
Car: 89 Formula
Transmission: TH 700R4
Car: 89 Formula
The point was he thought "H" was the 350 TPI code. HE was wrong and was corrected. No reason to freak out
The problem inlies with the efficency of the Engines in 1987. Because the cars were right on the limit for Fuel economy the LB9/A4 would have dipped below their estimates for fuel economy in a vert because the Vert is heavier and not quite as as Aero frendly. If they did offer it the A4 would have been about $1200 more to buy because of Gas guzzler taxes (which I do not understand as every time you fill up you give more to the Govt anyways so why shoudl they get something off the top too?)
This explains why the L98 was never offered directly but does not explain why the V6 was NA in 1987, might have had to do with Crash tests with the V6 in a Vert...
This is my argument to why Ponitac did not offer directly a Vert until 1991 when they lightened the body a little and made it more aero friendly.
John
John
.. The discription is correct for a 1987 IROC-Z with the standard LG4 305 with a carb.
