Gosh dern it. Looks like my build sheet has become one with my car
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
I'm starting to restore my camaro and I pulled the interior down today to see what the floors looked like top side. I was also praying to find my build sheet as I believe My car may be an IROC car. (Dash says it, and my RPO sheet is missing.) Well sure enough if my build sheet is about 5-6 in wide and 8-10 in long it has been worn away or someone pulled most of it out. By the looks of things I don't think my carpet was ever out. I'm not sure though. I could make out a few words. Norwood, Tires, (I think) probably a few others.
Oh well. I guess I'll never know if my car is an IROC or not.
For the record if what I found is the remains of my build sheet. It was under the carpet on the pasenger side right in front of the rear seat mounting bracket. Sorta glued to the floor it seems.
Re: Gosh dern it. Looks like my build sheet has become one with my car
You may be able to tell by looking closely at the ground effects. If it has been repainted at some point in its life they may have painted the ground effects black also. If you can see silver showing anywhere on the gfx's it is most likely a Z28. If you cant see silver showing anywhere it is most likely a IROC-Z.
Car: 1984 Camaro 'Vert
my build sheet was just a rust colored piece of paper... its usefulness long ago was worn away. Thankfully I already know my car is worthless, lol. So it was pulled along with everything else that was rotting and bad smelling.
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Car: 83 T/A, 83 S.C., 86 S.C. & IROC
Engine: 305 CFI &TPI
Transmission: 4L60E, 700R4
Axle/Gears: 3.23, 2.73
Did you take all of the carpet out including the cargo area? I found the remains of two build sheets under the carpet of my Trans Am. One was under the drivers seat and the other was under the carpet of the cargo well. Another popular location was the passenger door behind the door panel but I haven't looked there yet for another.
I did not find a build sheet in the door. If there was a build sheet in the trunk, it would have been part of the puddle of rusty watery stew I found in there.
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Your car must be worth alot to you... See its worth something...
Car: 1987 Firebird
Engine: 355
These are the only cars ive heard SO many places for build sheets. It would seem, (honestly) that they could be anywhere. Some of the places ive heard.
1) Almost everywhere under the carpet.
2) Under every seat, attached to the seat.
3) Under Dash pad.
4) Above gas tank.
5) In the sail panel area, where your speakers go. This one was unclear, im not sure if it attached to the cardboard of the sail panel, or just kinda sitting at the bottom in the opneing.
3) Under Dash pad.
4) Above gas tank.
Well the car's value has more to do with giving me a hobby. Its a bit of a mental health exercise more than anything!
And yeah, i don't know how, but the carpet in this car was always wet, even though all the seals were pretty good. I think that hole in the floor let in a ton of moisture.
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
My carpet or more the pading underneath was wet in the passenger side front foot well. More of an oily substance and smells funny. The heatercore probably isn't any good, but I'm not sure yet. Dash has to come out any how so I'll check it while it is out. I've got some scaley surface rust in strategically placed spots in my floor pan. Nothing through though. At least my screwdriver hasn't found its way through.
I noticed that padding is like a sponge. When my carpet came out, the first thing I did was rip the sponge off and throw it away. I'm trying to save the carpet, but I don't have any intention of keeping that nasty padding. I'm trying the peel n seal route for soundproofing, and I think with 2 layers its actually reasonable padding as well. its also not so prone to stay wet.
1992 Trans Am
May 10, 2023 07:19 PM
