1983 Z28 HELP? alittle advice please??? restro or restomod??
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Ok so this weekend I am going to look at a 1983 Z28 T top rolling cassis. It was a 305 auto car. I want your opionion on some things. Should I paint back two tone like the orig.? I was kinda thinking metallic black for the whole car and maybe the top side of the louvers on the hood sliver. should I restore the car to stock or make a weekend warrior out of it? My orig. plan was metallic black, 383, 6 spd, full black interior with some racing style front seats and making it a low 11's street car. I don't see many 82-84 z28's around are they getting rare? Is there anyway to tell what it orig. came with or how do tell if its a real Z? etc. any opionions are welcomed. Im getting excited
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: 1983 Z28 HELP? alittle advice please??? restro or restomod??
I have an 82 z28 all i can tell you is to check you vin and rpo's I wouldn't think they'd be all that rare thou I definitely wouldn't go back stock but it's up to you it's your car after all build it how you perfer
Axle/Gears: G92
where are the RPO's on these cars? in the hatch? thank you for your opionon.
think in the console not sure i know the earlier ones are in the hatch area mine was missing all interior when i got it so not so sure
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
If david068513 is talking about my car thats up for sale its a 84 Z28 HO 5-speed car. It has the RPO sticker on the box lid and it is a true 84 Z28. 82-84 Z28 are getting rare.
Car: 1992 Camaro RS t-top
Engine: 305 Jasper
The 383 stroker is the way to go; more $ than a 350 but if you have the funds, well worth it.As far as a paint scheme is concerned (I know it wouldn't be year correct), how about all black, but with ghost silver metallic Heritage stripes.I think that would be schweet!
But it's your ride- do what you want to do!!!
But it's your ride- do what you want to do!!! Thread Starter
Axle/Gears: G92
thanks for your help guys. Also were all the z28's crossfire or could you get a carb??
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
The crossfire was discontinued in 1984, so you could only get a carbed engine. In 82 and 83 not all Z28's were crossfire, that was an option. About the paint, unless you're going to pay real money for a high end paint job, it's best not to change colors. There's nothing more tacky than to open a door on a black car and see red door jams, or visa versa...Just my two cents.
Axle/Gears: G92
can you tell from the vin. which is crossfire and which is carb? etc. whats the Letter for a v8 in the vin in these years?
also what wheels did these cars come with? 15 or 16' and weren't they the single iroc wheels?
Axle/Gears: G92
also on 83's I read that they came standard with the clock in the concole but it was deleted if you got a radio with a clock? so does that mean a 83 without a clock in the concole would be more "rare" then one with it or the other way around???
Im so confused. im a late model(88-92) Guy but I feel in love with the 82-84 front end.
1983 LU5 "7"
1984 L69 "G"
1984 LG4 "H"
1984 L69 "G"
1984 LG4 "H"
Axle/Gears: G92
Axle/Gears: G92
The clocks to the best of my knowledge were an option not standard. Yes, in 84 if you got a digital clock the analog clock was deleted unless you still wanted it, in which case you ordered it as an option and could still get it. The word "Rare" and Third Gens don't really mix. You can use words like infrequent, uncommon, few and far between, but not rare....
I did a search On here and from what I read it was standard on the 83's. thanks for your help. TGO Supporter
Sorry, actually there were three..the L69 the LG4 and the LU5. The LU5 was discontinued in 84.
1982 Sport Coupe
Base (L4): RPO LQ8 / 151 CID 2-bbl carb (Canada & intl. only)
Base (L4): RPO LQ9 / 151 CID Throttle Body
Opt (V6): RPO LC1 / 173 CID 2-bbl carb ($125)
Opt (V8): RPO LG4 / 305 CID 4-bbl carb ($295)
1982 Berlinetta
Base (V6): RPO LC1 / 173 CID 2-bbl carb
Opt (V8): RPO LG4 / 305 CID 4-bbl carb (Unknown)
1982 Z28
Base (V8): RPO LG4 / 305 CID 4-bbl carb
Opt (V8): RPO LU5 / 305 CID Twin TBI ($450)
1983 Sport Coupe
Opt (V6): RPO LC1 / 173 CID 2-bbl carb ($150)
Opt (V8): RPO LG4 / 305 CID 4-bbl carb ($350)
1983 Berlinetta
1983 Z28
Opt (V8): RPO L69 / 305 CID 4-bbl carb High-Output ($450)
1984 Sport Coupe
Opt (V6): RPO LC1 / 173 CID 2-bbl carb ($250)
Opt (V8): RPO LG4 / 305 CID 4-bbl carb ($550)
1984 Berlinetta
1984 Z28
Opt (V8): RPO L69 / 305 CID 4-bbl carb High-Output ($530)
1985 Sport Coupe
Opt (V6): RPO LB8 / 173 CID MPFI ($335)
Opt (V8): RPO LG4 / 305 CID 4-bbl carb ($635)
1985 Berlinetta
Base (V6): RPO LB8 / 173 CID MPFI
1985 Z28
Opt (V8): RPO L69 / 305 CID 4-bbl carb High-Output ($680)
Opt (V8): RPO LB9 / 305 CID TPI ($680)
Note: The IROC-Z was an option package on the Z28 from 1985 thru 1987. Therefore, it will not be listed separately. Engine options were identical to the Z28.
1986 Sport Coupe
Base (L4): RPO LQ9 / 151 CID Throttle Body (Zero produced)
Opt (V6): RPO LB8 / 173 CID MPFI ($350)
Opt (V8): RPO LG4 / 305 CID 4-bbl carb ($750)
1986 Berlinetta
1986 Z28
Opt (V8): RPO L69 / 305 CID 4-bbl carb High-Output ($695)
Opt (V8): RPO LB9 / 305 CID TPI ($695)
1987 Sport Coupe
Opt (V8): RPO LG4 / 305 CID 4-bbl carb ($400)
Note: The LT was an option package on the Sport Coupe in 1987 only. Therefore, it will not be listed separately. Engine option (V8) was identical to the Sport Coupe, including price.
1987 RS (California only)
No engine options offered.
1987 Z28
Opt (V8): RPO LB9 / 305 CID TPI ($745)
Opt (V8): RPO B2L/L98 / 350 CID TPI w/IROC-Z option only ($1045)
1988 Sport Coupe
Opt (V8): RPO LO3 / 305 CID TBI ($400)
1988 RS (California, Texas & Florida only)
1988 IROC-Z
Base (V8): RPO LO3 / 305 CID TBI
Opt (V8): RPO B2L/L98 / 350 CID TPI ($1045)
1989 RS
1989 IROC-Z
1990 RS
Opt (V8): RPO LO3 / 305 CID TBI ($350)
1990 IROC-Z
Base (V8): RPO LB9 / 305 CID TPI
Opt (V8): RPO B2L/L98 / 350 CID TPI ($300)
1991 RS
1991 Z28
1992 RS
Opt (V8): RPO LO3 / 305 CID TBI ($369)
1992 Z28
Z28 Standard size rim was 15"
1982 Sport Coupe
1982 Berlinetta
1982 Z28
1983 Sport Coupe
1983 Berlinetta
1983 Z28
1984 Sport Coupe
1984 Berlinetta
1984 Z28
1985 Sport Coupe
1985 Berlinetta
1985 Z28
1986 Sport Coupe
1986 Berlinetta
1986 Z28
1987 Sport Coupe
1987 Z28
1988 Sport Coupe
1988 IROC-Z
1989 RS
1989 IROC-Z
1990 RS
1990 IROC-Z
1991 RS
1991 Z28
1992 RS
1992 Z28
Last edited by Kevin84Z28; Sep 20, 2008 at 12:00 AM. Reason: Automerged Doublepost
Axle/Gears: G92
https://www.thirdgen.org/forums/hist...light=1983+z28
here is the post I was referring too.
also twin TBI is cross-fire correct?
thanks for the wheel size.
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Sorry to jump on this thread, but I am having a real hard time finding a 1982-84 Z-28 front bumper cover. I checked online with Unlimited, and many other dealers. I called my local dealer also looking for one. I was curious if anyone knew of a good place to get a new cover.
I could get a used one but they seem to need some body work.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Kevin82Z28 you're partially correct on the LU5 Vin designator. In '82 the LU5 used a "7" but this was changed to a "S" for '83. The L69 oddly enough received the "7" for '83 then this was changed to "G" for '84. The LG4 used "H" for all years ('82-'87) it was used in the F-Body.
The only definite way to indicate a genuine '83 Z28 is having a VIN eight digit "S" for and auto car or "7" for a manual car. I say this because the LG4 ("H") was available in all models.
David yes twin TBI is referring to the Crossfire setup. It does work well if you have the patience to give it a chance. Better exhaust and intake mods definitly wake them up.
The console clock (RPO-U35) was standard on the Z28 '82-'85 but was deleted if a integral clock/radio was ordered. It could still be ordered separatly as my '83 was. They are neat looking but troublesome -especially the second hands.
The closest thing to a SPID the '82-'83 cars have is the trim tag on the center top of the radiator support. It gives paint code/type,interior code/type/color,seat type,CC1 for factory T-Top cars along with other trim codes. If you're lucky you'll find a build sheet somewhere in the car (in or under seats,under carpet or behind door/trim panels) or not at all.
The '82-'84 Z28 ,even the SC and Berlinetta, are a less common sight because a lot of people convert the nose/tail/GFX to the '85 up versions. Personally I prefer the look of my '83 Z28 over the later cars. The hood on the '83 Z28 can either be steel or composite. And if a Crossfire car that composite hood has functional intake louvers.
My '83 is an original (and still) LU5 car and has every option except the rear wiper,L/S seats and Camaro letter interior. Oddly she had mounting posts for the upper console when i got her. The holes for these are stamped into the metal and not drilled so it has me thinking the upper console may have been a late '83 release like the L69. My car was built the 3rd week of June '83 so she would have been in the last run of '83 I believe.
Hope this helps.
Hope this helps.
Car: 91 Formula
This site, Ebay etc. you can find most of the parts you need.
Shipping of a bumper cover is expensive and most people have troubles paying around $100 for shipping.
Axle/Gears: G92
Hope this helps.
Hope this helps.
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
you should definitely paint it the original black and silver two tone i think that is the best color for an early third gen z i wish my 84 was that color but she was original blue and silver than a po painted it all a light blue-purple color so thats what im stickin with for now lol cant wait to see pics of yours
you should definitely paint it the original black and silver two tone i think that is the best color for and early third gen z i wish my 84 was that color but she was original blue and silver than a po painted it all a light blue-purple color so thats what im stickin with for now lol cant wait to see pics of yours
Brennan, you should get the 84 Z28 hood decals for your scoops. They would look good. www.phoenixgraphics.com very inexpensive.
i got it in the garage a few days ago and me and dad put some new shocks and springs in the rear and im gonna do a bit of maintenance to it and then its gonna be torn down for paint. the jambs and everything are already blue so thats what im goin with and possibly some silver striping check my cardomain for pics of the accident and before pics links in the sig
