2hy rear axle code on a 86 iroc?
Old Dec 5, 2008 | 08:44 PM
bmfIROC-Z's Avatar
well i was a little curious if my car actually came with the g92(3.42 posi)option but none of the rpo code sheets are in the car anymore,so i did some digging to see if there was any other way i could find out what gear ratio came in my car and i found a website that said to look for a code in the front of the right axle tube and i found the code it is 2H Y C311 1 and on the same site it says the 2h y means 3.23 posi,so im a little confused cause in the 86 camaro tech articles it says that an 86 lb9 A4 came with 2.73 standard or 3.42 with the g92 package ,so does this mean my rear end has been swapped out or am i missing something?any insight would be appreciated,thanks in advance ,joe
Old Dec 6, 2008 | 06:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 2hy rear axle code on a 86 iroc?
Originally Posted by bmfIROC-Z
...im a little confused cause in the 86 camaro tech articles it says that an 86 lb9 A4 came with 2.73 standard or 3.42 with the g92 package ,so does this mean my rear end has been swapped out ...
The only way to know positively is to drop the diff cover and take a peek.
JamesC
Old Dec 6, 2008 | 08:12 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
My 86 IROC came from the factory with 3.23's posi and it was one of the last one made.It had a lot of the 87 options.
Old Dec 6, 2008 | 12:55 PM
bmfIROC-Z's Avatar
do you know if yours came with the g92 option?
Old Dec 6, 2008 | 01:20 PM
mr396's Avatar
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
The standard catalog of Camaro states the 1986 camaro came standard with 3.23 gears the 3.42 was option G92.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
mustangman65_79
Aug 11, 2015 03:17 PM
