Where is SPI sticker located on '88 Z-28?
Old Jan 21, 2009 | 01:44 PM
SamS's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7L
Transmission: 700R4 Auto
Axle/Gears: G92 3.23
Hi,
I am trying to find out more about a car that I can't see in person. I have asked the seller to find the SPI sticker in the console glove box. Isn't this where it should be located? Guy can't find it, I don't think it's removed, he's just not looking in the right spot
Old Jan 21, 2009 | 01:57 PM
Stephen's Avatar
Car: 87 GTA
Re: Where is SPI sticker located on '88 Z-28?
4 possibilities......
Inside bottom of the console lid...
Inside bottom of the rear "glove box" lid
Under the carpet
Or just thrown away....It was fairly common (it seems) that people o the assembly line just threw them away, instead of putting them in the car. My 87 GTA seems to be one of those last option cars, no SPID.
Old Jan 21, 2009 | 02:04 PM
SamS's Avatar
Engine: 5.7L
Thanks Stephen.
You mean in the rear/hatch storage area opposite the spare tire compartment?
Old Jan 21, 2009 | 02:06 PM
Stephen's Avatar
Car: 87 GTA
Yeah...I've seen it in there before.
Good luck.
Old Jan 21, 2009 | 02:10 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
where at under the carpet??
Old Jan 21, 2009 | 02:11 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
ALL SPID sheets were installed in the center console from the time GM started using them in 1984 thru mid 1991. Starting in 1991 they moved them to the rear hatch area except the verts where I believe they remaind in the center console.
John
Old Jan 21, 2009 | 02:15 PM
Stephen's Avatar
Car: 87 GTA
John
Thats where they were SUPPOSED to be put. But have also been found just tossed in, then the carpet put in over them. Unlikely, but possible & a last effort.
Old Jan 22, 2009 | 08:06 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The SPID label was never just thrown in. You are thinking of the build sheet. Those were not always in the car. The SPID sticker should be under the lid of the center console or on the side of the center console.
Old Jan 22, 2009 | 08:10 PM
Stephen's Avatar
Car: 87 GTA
Ah yes...Build sheet. Your right. Thats what I was thinking of.
But I've never heard of a SPID on the side of the center console. IN the console or rear "glove box", but not on the side.
Old Jan 22, 2009 | 08:21 PM
scottmoyer's Avatar
Mine is on the passenger side, inside of the glove box. I can see it clearly while sitting in the drivers seat.
Old Jan 23, 2009 | 08:32 AM
okfoz's Avatar
My SPID sheets are all on the passenger side of the center console when you lift the lid.
John
Old Jan 23, 2009 | 10:01 AM
Stephen's Avatar
Car: 87 GTA
I can't make sense of neither of ya'lls descriptionsof where ya'll are seeing it.
With regards to the console, I've only seen it INSIDE, stuck to the bottom of the lid, meaning you can't see it, until you OPEN the lid.
Both of ya'lls (scottmoyer/okfoz) descriptions don't make sense o me. Do ya'll mean INSIDE, bottom of the lid, or ?????????
Old Jan 23, 2009 | 02:18 PM
okfoz's Avatar
Nope, ALL THREE of my SPID sheets are on the INSIDE of the compartment NOT ON THE LID, when you open it the tag is on the Passenger side staring at you. If you have any junk in there you can not read it... ALL of the SPID sheets that I steal from junkyards are located there. Not like they are worth anything...
John
PurelyPMD
May 5, 2016 04:57 PM
codeysabatini
Nov 10, 2015 04:07 PM
Nikole
Sep 24, 2015 08:12 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
