Original Grey Valve Caps
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i been pulling grey valve caps off GM cars spair tires in j/y's left and right and i have come up with 2 styles?? one has a smooth top and the other has a raised circle on it im not sure if this pic is good enough to see the diff in the 2, but was wondering if someone knew what one was correct for 1989
in the pic the 2 in the center have the raised circle on the top
Re: Original Grey Valve Caps
yea that pic does suck, thanks for the info, anyone know id the smooth rounded is for all 3rd's........that way i know what to pull, try to get some for some other members
I've been through this a while back, looks like the 2 on the outside of that pic are the correct ones, with the smooth tops, the center ones with the "nipple" on them are for newer cars. There is a member that has found the closest possible new match to the originals, but if you can get the original ones that is nice.
me and a friend go to the j/y for the heck of it, just to see what we can find that we can use for different projects
i always look at the spair tires on 80's GM to get the caps lol
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Yep I'm that member :-) Still got some ...
Here's the original thread with good pictures of the one's GM used back in the days (smooth top) and the ones I found (and use on mine) ...
https://www.thirdgen.org/forums/hist...ray-valve.html
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
