ws6
Old Mar 19, 2009 | 09:13 PM
worxsinprogress's Avatar
ws6
In 84, what options were on the ws6?
Old Mar 19, 2009 | 10:39 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: ws6
12.7 ratio steering box, higher rate springs, stiffer suspension bushings and struts/shocks, 32mm/21mm(23mm-late production) front and rear sway bars, torque arm with lightening holes, locking rear differential, 4-wheel disc brakes, and 15"x7" size rims with P215/65/15 Goodyear Eagle GT performance radial tires.
Old Mar 19, 2009 | 11:14 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Re: ws6
How late in the production did they get the 23 mm sway bar. I am guessing mine is 21.....for a July car?
Old Mar 20, 2009 | 02:21 AM
Re: ws6
Thanks. Just wanted to make sure mine was a ws6.
Old Mar 20, 2009 | 11:52 AM
Dens71TA's Avatar
Re: ws6
I'm not sure. My '84 T/A WS6 was built 5th week of 8/84 and has the 23mm bar. Yours might have the 23mm rear bar.
Old Mar 20, 2009 | 12:40 PM
L695speed's Avatar
Re: ws6
I will probably measure it when I get home tomorrow. I am planning on getting work done on the hood, tow bar comes off, and if I am lucky it will be running sometime this weekend. Thanks
Old Mar 20, 2009 | 01:03 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: ws6
The torque arm information is interesting. I noticed that mine looked like swiss cheese and decided to go with the LT1 version that was much more solid.
Old Mar 20, 2009 | 02:07 PM
Dens71TA's Avatar
Re: ws6
My '84 T/A parts car has the standard Level II Y99 suspension and a solid torque arm. It looks like it has some weight to it. Not good for handling.
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
dbrochard
Sep 7, 2015 09:41 AM
neekolzun
Aug 24, 2015 04:59 PM
