Rear Window Wiper/Washer
Car: 1988 Camaro IROC
Transmission: Auto overdrive
Axle/Gears: 3:23
Re: Rear Window Wiper/Washer
David,
Thanks for that information. I know a person that has a yellow 1985 Z28 with the rear wiper and I have never seen many Camaros or Firebirds with that option.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
edit: nevermind i just went and checked, its in the same spot as kevins. i was thinkin about the defrost switch. on another note do gm still make these switches mines all faded and ugly
i edited my previous post. its been to long since ive driven my car! hurry up spring!!!
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Car: 1986 Camaro IROC-Z
I have an 86 with a rear wiper, the switch is in the center console where the windows and trunk release buttons are
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 1986 camaro iroc-Z z28
Engine: 305 tpi 5.0
Transmission: Auto 700R4
yes!!! found it but thanks for your help, couldnt buy the one on ebay lol i have it installed now
Car: 1982 Camaro Pace Car
Engine: LU5 Crossfire
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
I was doing research on possibly buying and saving a rear wiper (ONLY because it was an option on the Camaro) for later use maybe. Anyway, when going through the boards; the swith location varied quite a but depending on what options came on your car. If it had lots of options, it was located down on the lower dash, if low options it was either fog light location or rear defrost. Console mounted - that is the first time I saw that location, doesn't make much sense if you had power windows and rear hatch release.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
