9 bolt borg warner rear end vin numbers
Car: 1991 Camaro RS
Engine: 305tbi
When I got my 1991 RS Camaro the owner had cut a 9 bolt Borg Warner rear end from another Camaro at a junk yard. It had a tag but kind of hard to read but I have most of the letters and numbers. How can I find out what car this rear end came from and what it is geared at and what year it was made in? Any help would be great and a good start.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: 9 bolt borg warner rear end vin numbers
There should be some numbers stamped on one of the axle tubes... I want to think it was the Drivers side.
John
John
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
you can pop the diff cover and roll the ring gear around and the actual ratio is stamped on the side of it.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
My 9-bolt didn't have any numbers stamped on the axle tubes, it was all on a tag. One cheap way is you can rotate the wheels and count the number of times the yoke turns, if it turns 2 3/4 times around it would be a 2.77, 3 1/4 it would be a 3.27 etc etc
Car: 91 Camaro RS
Engine: LS - 6.0 Warmmed over ---
Transmission: M21 - Gear Vendors Overdrive Soon
Axle/Gears: 3:27 Aussie 9 Bolt Positraction
Just checked my axle yesterday, no stamped numbers, but think that was GM markings only for the 10 bolt. I only have a tag bolted to the diff house. Production date is there IF you have the tag. Rear gears I think have embossed value of number of teeth. Should be located on the larger ring gear.
Now that you mention it I do remember that now... I think you are right, the gear ratio is actually on a tag that is bolted to the Dif Cover... There was a larger tag with instructions to add the posi additive on the other side
The ID is 1) on the tag, and I think it was 2) identified by the large sticker...
The Tag has a Part number of the Axel, and the Gear Ratio
John
John
hectre13
Dec 11, 2023 08:14 AM
theshackle
Sep 17, 2020 08:26 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
