OUICK QUESTION
Car: 85 IROC-Z
Axle/Gears: stock 3.23
OUICK QUESTION
I have a 85 IROC that I did a engine swap with a 87 (also a 305 tpi). If I were restoring the car would it make a difference with that motor or would I need to rebuild the 85 motor?
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: OUICK QUESTION
own preference really. if u want to be that **** about restoring her then yes rebuild if not then swap. it just wont have orginal motor.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: OUICK QUESTION
Off the top of my head
Numbers matching...
Every car has a VIN, as an example 1G1FP2188HL223456
On the Engine block and the Transmission case the following should be found 2HL223456
2 = Pontiac
H = 1987
L = Van Nuys
2 = Pontiac
23456 = Sequence number...
John
Numbers matching...
2 = Pontiac
H = 1987
L = Van Nuys
2 = Pontiac
John
