Need a person that has an original Cross Fire to help me:)
Old Jul 1, 2009 | 12:41 PM
kobrak's Avatar
Car: 1983 Z28 Camaro
Engine: 350 block with original Cross Fire
Looking for an unmodified Cross Fire Camaro....1983 to help me locate a coupla vacuum lines and a fused plug coming from the hood Let me know and I'll send a few pics to help understand what I need as far as location. My aircleaner has two vacuum connectors coming from the underside of the factory aircleaner.......don't no where they go
Old Jul 1, 2009 | 10:27 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Need a person that has an original Cross Fire to help me:)
I have an 82 and 83 right now. What do ya need?
Old Jul 2, 2009 | 07:59 PM
kobrak's Avatar
Awesome! I'll send you a coupla pics of what I'm talking about. Give me a day or two as I can't fin my cable that hooks to my camera. Basically I'm trying to find out where the vacuum lines (two) plug into from the right side underneath of the original air cleaner. I'm also trying to find out where the two electrical connectors go from the ram air hood. They make the flaps open The one I can't find the other end for has a fused link before the connector.
Old Jul 6, 2009 | 01:15 PM
kobrak's Avatar
jkris, I found my camera cable, I'll gt a few pics posted tonight hopefully!
Old Jul 6, 2009 | 11:37 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
kobrak
The black wire with stripe color?? with the fuse in it is for the under hood light. In my 82 it has a special adapter that splices it into the red wire going to the blower motor.
The black wire with stripe color??? from the air louver solenoid on the hood connects to a single orange wire next to the distributor, joins a wire bundle to the driver's side and exits at the two relay on the fire wall. One relay is for the fuel pump and the other receives a signal from the ECM and open the hood louver. Look for the relay with the orange wire, among others that comes out the bottom. In my 82 the fuel pump relay is closest to the distributor and the louver relay is next to the fender.
I will have to check the stripe colors. Note that in these photos, the orange wire looks yellow. The red wire is for the high speed power to the blower motor.
Note that the air pollution stuff is off my car at the moment, as are the exhaust manifolds, so it is a bit easier to see a few of the wires. I will post the relay photos in the next message.
The left photo shows the wiring just above the blower and A/C. You can just see the fuse at the right side of the photo. In the middle photo I am holding the wire that operates the hood louvers. The wire color changes to orange on the other side of the connector. The third photo shows the hood light wire tapped into the high speed blower motor red wire. Note I have pulled the fuse connector apart so you can see part of it in the photo.
Dave
Attached Thumbnails Need a person that has an original Cross Fire to help me:)-82_hood_wiring_007.jpg   Need a person that has an original Cross Fire to help me:)-82_hood_wiring_008.jpg   Need a person that has an original Cross Fire to help me:)-82_hood_wiring_009.jpg
Old Jul 6, 2009 | 11:54 PM
Here are the photos of the relays. Note that the orange wire of interest is yellow colored in these photos. It is the left wire on the relay.
For your vacuum lines, look on the top of the fan shroud. There should be a sticker detailing the vacuum line connections. You might have to study the diagram and the top of the TBI intake cover, but you should be able to figure it out. Let us know if you still need some assistance or more photos.
Dave
Attached Thumbnails Need a person that has an original Cross Fire to help me:)-82_hood_wiring_001.jpg   Need a person that has an original Cross Fire to help me:)-82_hood_wiring_002.jpg   Need a person that has an original Cross Fire to help me:)-82_hood_wiring_003.jpg
Old Jul 8, 2009 | 04:31 PM
kobrak's Avatar
Ok, thanks a bunch! I think I understand here. I was not even thinking about the hood light The other for the loovers I do have plugged in. I'll have another look at the vacuum lines tonight
Old Jul 10, 2009 | 10:40 AM
kobrak's Avatar
Thanks for all of the help, everything is buttoned up. You were right, there is a diagram plain as day on the cowl!!!
One peice left to the puzzle.........I need one air cleaner bolt/barrel to tighten the thing down. Somehow I lost one???
Old Jul 11, 2009 | 10:25 AM
Well sometimes that diagram is not there any more. Good to hear that you got everything hooked back up.
As for the air cleaner attachment "nut" I have no idea where you might find one of those, except maybe at a junkyard (once in a blue moon) or in the TGO For Sale boards. Guys are always tearing the CFI engines out of their cars and trying to sell off the pieces of the engine. Sorry to hear that it went into hiding on you.....
Dave
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
TheExaminer
Aug 19, 2015 10:07 PM
