**Project PITA** 86 TA frame up restoration
#951
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: **Project PITA** 86 TA frame up restoration
Ordered my tuned PCM today! Hopefully it comes by this weekend so I can fire this thing up! Engine harness is basically completely installed except for a few connections like the tach, speedo, etc. I'll keep you all updated as to when I'm going to be ready for startup.
#952
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
No sh**. I didnt know you had the harness. You might actually get to drive it this season?
#953
Car: 1986 Trans am
Engine: 5.3 LM7
Unfortunately, probably not. Still going to have to get it tuned and the entire frontend painted. But it will run in the next week or so at least! Then I'll have all the motivation in the world to have it on the road for next spring. I have no doubt it'll be done way before spring hits though so I am pretty excited to drive my baby after being off the road for 4 or so years!
#954
Car: 1988 Iroc
Engine: 5.7L
Oh I know, when I said "drive" i meant it will be able to move under its own power.
#955
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Good **** man! Hopefully I'll be there for the initial fire
#956
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Axle/Gears: 10 bolt 3.73
hey man i had a few questions on the wiring harness. im ordering a similar harness and want to know what you did to wire up the trunk hatch, all the lights for breaks, and the defogger relay. would it be possible for you to take pictures of what you did or possible give me a description and part numbers to anything you needed to make this possible? thanks
#957
Car: 1988 Iroc
Engine: 5.7L
#958
Car: 1986 Trans am
Engine: 5.3 LM7
I'll give ya a ring and we can celebrate with a few smokes! That is if it doesn't send a rod through the block..
I'll let you know too. If your not busy, feel free to swing by with Arthur.
#961
Car: 1986 Trans am
Engine: 5.3 LM7
Few more pics from today...
Heres where the harness runs into the cabin. I have to make a little plate to put the grommet into but thats about it.
And heres the completed engine bay. All wires are run and plugged in, and she's ready to go. So glad I decided to run the headlight wiring through the framerail because the only visible wiring is on top of the motor and it blends right in. Also need my downpipe back on, but thats it!
#962
Car: 1989 IROC
Engine: 6.0L Twin GTK450
Thats clean.. gotta say man, you've done a great job.. cant wait to hear it
What size down pipe do you have
#963
Car: 1988 Iroc
Engine: 5.7L
Not related to your build, but I noticed you have the Tokico non adjustable shocks, how do you like them? Im working on specing out my suspension parts now.
#964
Car: 1986 Trans am
Engine: 5.3 LM7
Well, in the short time I drove the car with them, they seemed great. Havn't really had the chance to test them out on any twisties, but a ton of guys use them so I'd have to believe they are good.
#965
Car: 1991 Z28
Engine: 5.7
Excellent build. Thank you so much for taking the time to document it with pictures. I can imagine how much a pain in the *** that can be at times when your in the middle of something and reach for that camera lol.
You've opened a can of worms for yourself now. You'll never be done. Next summer when it's "done" you'll be fiddling with the tune constantly just because.
You'll have a long weekend and be yanking the engine wiring harness to better route and hide it. Then there's that stainless exhaust. The adjustable shocks. The bigger turbo. The dual turbo and on and on lol.
Soooo worth it though
Keep up the good work!
#966
Car: 70 Chevelle
Engine: 396
Transmission: TH350
are you putting the other 4 gauges in before you start it up the first time? i been meaning to ask you that. i also had another question about the wiring, how did you run your wires to the trunk release switch on the dashboard? i think you said you used the trunk light wire for the trunk release mechanism. i just order my harness last night and i want to get as much cleared up as possible before i start wiring up my formula
#967
Car: 70 Chevelle
Engine: 396
Transmission: TH350
oh yeah shouldnt the computer be coming in for the car? its been almost a week!!!
#968
Car: 1986 Trans am
Engine: 5.3 LM7
I was hoping it was going to come sat but it didn't. Guess I'll have to wait until monday now and hope it's hear! I hate waiting for things in the mail haha.
#969
Car: 1986 Trans am
Engine: 5.3 LM7
Today was a VERY great day in the history of project PITA. She fired up on the first crank! oil pressure is around 35-40 psi at idle once warmed up, no leaks, no smoke, and she purs like a kitten! Throttle is very responsive though I didn't want to rev it too much with the turbo being not fed into the intake. Anyways, heres a youtube vid of it running!
http://www.youtube.com/watch?v=AHXB_Z69Htc
#973
Engine: LB9
Very special day for Project PITA indeed; sort of feels Holy as a matter of fact.
http://www.youtube.com/watch?v=e4q6eaLn2mY
#976
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Congrats. Major milestone in a project of this size. You'll sleep good tonight.
And kudos for thinking this through so thorougly. And documenting it so well.
This car is going to be very fast and very reliable.
#977
Car: 1986 Trans am
Engine: 5.3 LM7
Thanks everybody! Feels great knowing that all this work paid off. And to see it fire up on the first crank just made it that much better. Before I turned the key, I was almost doubting myself and thinking it probably wasn't going to start...and then BAM, just came to life and ran perfect right off the bat. I did find out after running it for a little while that my radiator has a small leak in the plastic end tank, but I guess I have an excuse to upgrade to an aluminum one lol. But thats a minor detail compared to everything that COULD have gone wrong. Next up I plan on getting the intercooler and buttoning up the cold side piping. Then maybe I can get it tuned to see what it's really got.
And eseibel67, I plan on sleeping like a ROCK tonight, lol.
#978
Car: 1986 Trans am
Engine: 5.3 LM7
Figured I'd post a few pics up of the autometer cobalts lit up. I even hooked them up so that they dim with the factory dimmer switch! I love when things work like factory.
#982
Car: 1988 Iroc
Engine: 5.7L
Well, I think I found the gauges Im going to used when I build my autometer dash. THose cobalt gauges look awesome!
#983
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Looks awesome glad you gotmit started man been following this for a while inspires me to work on my car
#984
Car: 1986 Trans am
Engine: 5.3 LM7
I have my intercooler now on the way. Tracking number says Thursday next week. Damn California orders! Also found out my radiator did not leak. It was actually the lower radiator hose. I had put a clamp on it that was too big for the hose, so when I checked if it was tight, it felt tight. Upon a second look, I noticed the worm gear on the clamp ran out of threads and was eating into the metal, making it feel tight haha. Put a smaller clamp on and we are good to go.
I'll probably be able to order the cooling fans this coming week as well and once those go in, I'm taking her for a little test drive around the block!
#985
Car: 2001 GMC Sonoma 4.3/ 84 Trans Am
Engine: SBC 355
Transmission: 89 World Class Borg T5
Axle/Gears: 3.42 10 bolt
what a build dude...looks very sharp. You did this car the right way from the looks of it..I am restifacting my 84 currently and already running into a few problems. Couldn't imagine working on a car for 4 yrs without driving it. It's been 3 months for me I am already dieing. I'm going to keep on your thread I like what you have done here.
#986
Car: 1986 Trans am
Engine: 5.3 LM7
^^ Thanks man!!
And as an update...I got a little dose of very bad news today. I was considering taking the car around the block, so I went to go into reverse.....and nothing. Shut the car off, put in in reverse, started it back up, and when you let off the clutch, it sits there and idles. The pitch of the motor doesn't even change. It's like theres not even a reverse there. All the forward gears work which points me to the tranny itself having an issue. Needless to say I'm pretty pissed after paying $1000 for a supposedly "rebuilt" tranny. I plan on pulling it in the next week to have a buddy of mine pull the tailshaft and check out the reverse parts. I'm not a very happy camper at the moment, but hey I guess $hit happens, right? I just hope it's an easy and semi cheap fix.
#988
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The lockout prevents the shifter from even getting over far enough to the right gate so you can't engage reverse. If it clicked into 5th by accident due to lockout the engine would stall when engaging the clutch.
This is a dumb question, but I'm sure you had the shifter all the way up and clicked in to reverse, right? Just trying to prevent a tranny removal if possible.
#989
Having rebuilt other transmissions, I am wondering if there isn't just an incorrectly aligned part in the trans, ie the internal reverse linkage did not mate properly when it was assembled? Or maybe a piece left out? I have no T56 experience, so I can't speculate any further.
I can tell you that when I rebuild a trans, I always verify engagement into all gears and rotate the input shaft to be sure that all has gone back together right. Whoever did yours should have done that also.
#990
Car: 92 Firebird
Engine: 4.8 LR4
This may be a possibility. I can get my T56 "into" reverse but not have the gears engaged. I then have to stop and then push it a little further up to get the gears engaged
#991
Car: 1986 Trans am
Engine: 5.3 LM7
#992
Car: 1988 Iroc
Engine: 5.7L
Thats weird a weird problem. To me it sounds like something is not lined up. Almost like when selecting reverse there is no reverse gear there to engage, similar to neutral. Or seems almost like the reverse fork is missing and no reverse gear is getting moved. I know both of these probably arent likely but im just thnking out loud here.
This is the reason im sending my T56 to Tick performance. I rebuilt the T5 but dont want to mess with the t56.
#993
Car: 1986 Trans am
Engine: 5.3 LM7
#994
Car: 1988 Iroc
Engine: 5.7L
I MIGHT attempt to build mine, but have been told it gets really harry if you have to replace the bearings and re shim it. Thats what worries me or there would be no question I would build it.
Yeah, my guess is something with the shift fork, let me know when you figure it out.
#995
Car: 1986 Trans am
Engine: 5.3 LM7
Just took her for her maiden voyage around the block, and I have to say, the car drives BEAUTIFULLY! Engine runs smooth and from even right off idle it feels like it has plenty of power accelerating. I was nervous because some guys say when you drop the compression on a 5.3 to 8.5:1, it is a dog down low. But even compared to a stock 305 TPI, it feels like it has plenty more power even without the turbo hooked up, so I'm happy. Ran very smooth and shifted great through the forward gears. You sure can tell you are driving a car with a newer engine just because of how smooth and responsive it is. My intercooler should be here thursday and I can't wait to get the piping all plumbed and drive her with the turbo hooked up! Just can't give it much gas till it's tuned.
#996
Car: 1986 Trans am
Engine: 5.3 LM7
Got my intercooler in the mail today and fabbed up a mounting bracket for it. Fit's perfect in the area in front of the radiator. Now I just need to hope the car still cools nicely with dual pusher fans since there won't be a whole lot of airflow through the intercooler. I'm considering making a scoop in my front bumper with ducting to the intercooler and radiator but am not sure yet. Anyways, heres a few pics.
Heres the bracket I made up which will be welded to the front subframe where the crash bar meets it. Just need to paint it then it can be welded on.
Heres where the piping comes out of the intercooler, Just under the subframe. From here it will run up through the battery tray and into the throttle body.
#997
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
looks great! any room for ac in there?
#999
Engine: LB9
Won't be much longer till you can REALLY let her rip on a neighborhood joyride...
#1000
Car: 1986 Trans am
Engine: 5.3 LM7
I wish I could have fit AC, but between the turbo downpipe being tight by the AC box area, and the intercooler and dual front mounted fan setup theres just no way. Oh well, given the option, I'll take HP over being cool haha.
Oh man I can't wait! I sent an e-mail to a local turbo shop today to try to get all the silicone couplers and piping that I need in one shot. Waiting to hear back from him now, so hopefully the piping is done in a few days.
