rear end ratio puzzling
Car: 1986 Camaro Z28
Engine: 355 4 bolt 4bbl
Transmission: T-5 manual
Axle/Gears: 3.73 posi.
I've got an 86 Z28. the option list on this site says that the LG4 automatic only came with a 2.73 rear. But my RPO's are LG4 (305 4 bbl) MD8 MX0 (700 R4) and GU5 (3.23) rear gears. Also on the right axle tube there is PH stamped and I can't find any info on that. It is also a Canadian car if that makes a difference.Thanks.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end ratio puzzling
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
When in doubt, trust the RPO codes. Just make sure the vin on the SPID matches the vin on your car. The tech data on this site isn't 100% flawless, it's just a guideline.
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
It's an old car. My experiance is people don't usually change gear oil in the diff as a maintenance thing. Spend a few bucks, pull the cover off and get the numbers off the gears. Mystery solved and new oil in diff.
Thanks guys. Doesn't really matter though cause just bought a posi carrier and a set of 3.73's.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Mine didnt match the data either. I dont have my rpo's but my car should have had 2.73 , but i opened the diff and it has 3.42. The brakes werent hooked up right either, so im guessing th Po swapped in an axle from a V6 car.
Its got drum brakes. Its a 10 bolt 7.5 with 26 spline axles.
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Engine: 4++,350 & 305 CIs
One of my cars is rpo 4 2.73 open.
the axle is coded 4 2.73 posi but it has a (GM gears) 3.08 open..
I have looked and looked 4 any clue 4 a rear swap but cant find any..
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
