LS1 & 4L65E?
Old Feb 24, 2010 | 11:12 PM
Fred007's Avatar
Car: 1990 Jeep Wrangler (YJ)
Transmission: 4L65E
Axle/Gears: Ford 8.8 4.11:1
LS1 & 4L65E?
Anyone know of a car offered with an LS1 and 4L65E? Could be a 4L60E as well, I've been told there is no difference in the PCM tables for these two. I ask because I have an LS1 from a 2000 vette in my Jeep and am putting in a 4L65E and need a base tune file to program my PCM. I was told by one programmer that I should not use the vette stock tune because of the trans axle. I'm new to the whole tuning thing so would appreciate any help. Thanks.
Old Feb 24, 2010 | 11:38 PM
Stephen's Avatar
Car: 87 GTA
Re: LS1 & 4L65E?
Isn't the LQ9 basically an bigger displacement, iron block version of the LS1. And the LQ9 came with 4L65E, right? In full sized trucks?
If so, I see no reason a LS1 PCM couldn't control a 4L65E just as easily as a 4L60E.
Old Feb 25, 2010 | 12:51 AM
Drew's Avatar
Re: LS1 & 4L65E?
I think you took a wrong turn at the Tech Boards. History/Restoration is for the discussion of 82-92 Camaro/Firebird history, and restoration. Maybe try the engine swap forum or tech/general forum.
Old Feb 25, 2010 | 07:00 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: LS1 & 4L65E?
Either way, even in the engine forums, the LS1 and 4l60E is a 4th gen engine and trans setup, not thirdgen.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
