cluster glass restoration
Old Mar 6, 2010 | 09:08 AM
hinton38's Avatar
Car: 1987 Black Iroc Camaro
Engine: 5.7l TPI
Transmission: a4 automatic
Axle/Gears: borg warner9 bolt 3:.27
the plasctic covering my cluster is in good shape but it got all kinds off fine scratches on it is there any thing i can do to get these out and have it looking new again?
Old Mar 6, 2010 | 09:14 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: cluster glass restoration
You could try some plastic polish.That might help you out
Old Mar 6, 2010 | 09:15 AM
hinton38's Avatar
Engine: 5.7l TPI
is that the stuff they use on the newer headlights to get them clear again
Old Mar 6, 2010 | 08:57 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
That was something I have always wondered about too. I have the same problem on my Digital dash in my GTA. My idea was to get a hold of some of the clear shiny plastic that screen protectors for Ipods, Psps, ect are made from. That stuff is super shiny, doesn't scratch easy, and wouldn't show the mini scratches in the plastic through. I just have to figure out where to get some from, I bet it would work amazing...
Old Mar 6, 2010 | 09:40 PM
Drew's Avatar
As has been mentioned, any quality automotive plastic cleaner/polish will remove most hazing and light scratches, and polish the plastic lense until it's clear as glass.
Old Mar 10, 2010 | 09:16 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The lens' are made from a cast acrylic, and you can use any automotive paint polish that you want on them as acrylics have been used in paints for a long time. Obviously it is easier to remove the lens from the car and polish on a bench than it is to polish in the car... Usually the plastic is soft, so I have even been successful at sanding with fine sand paper and polishing them out to get off hazing left by or created by some chemical probably used to clean the interior.
Be careful if you use a power buffer, as it can catch an edge and throw it across the room... then you have to buy a new lens... usually junkyards want to sell a cluster, so you buy a new cluster... I actually like to use a DA sander with a buffing pad, its not as agressive and it does go slower, but I get really good results with 3M White polish compound...
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
