what engine do i have???
Old Mar 7, 2010 | 06:34 PM
1990s10's Avatar
i recently purchased a 305 tpi from a guy in maryland. a friend of mine heard the engine run before it was pulled. it was said to have been in a 86 GTA and had digital guages but car was totalled and then went into a camaro. it was totalled soon after being new? motor has 50-60k on it. I did a lil reasearch on that and i believe and correct me if i am wrong but i believe at worst case its an 87 engine? i pulled the trans from it today and got all the number i could find on the block and the heads. i am hoping someone who reads this thread will be able to check into what this is
here are the numbers from front to back
V0226sfw
2HN230574
right and left lower end
627
back
H12
638
top rear
GM 5.0LG 8207 14093627
Old Mar 7, 2010 | 08:22 PM
Drew's Avatar
Re: what engine do i have???
Mortec.com says it's a 87-94 305. Check the head numbers. Pull the valve cover and there will be a casting number. That'll tell you if it's a LG4, LB9, or L03.
Old Mar 7, 2010 | 08:31 PM
JT's Avatar
JT
Community Administrator
And just to add, there wasn't a production 1986 GTA as the first production year for the GTA was 1987. There was the Trans AM, which could be equipped with the digital dash in 1986.
Old Mar 7, 2010 | 08:41 PM
Drew's Avatar
86 Engines had perimeter bolt valve covers, a flat tappet cam, and a 1 pc rear main seal. It's more likely the donor car wasn't an 86.
Old Mar 8, 2010 | 12:22 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
V0226sfw
2HN230574
627
back
H12
638
top rear
Hello 1990s10!!
Your engine "block" comes from a 1987 Camaro bulit at the Norwood Ohio plant!! Probably sometime around mid to late March 1987, engine build date usually preceeds car build date by about 15-30 days!!!!
V = Flint Engine
02 = Month of Manufacture
26 = Date of the Month of Manufacture
SFW = 305 with auto transmission
2HN230574 This number doesn't work, 1HN230574 does, and will verify my info above!!
2HN230574 would break down as follows:
2 = Pontiac
H = 1987
N = Norwood Ohio
230574 last 6 digits of the vehicle VIN #
However, all the decoders that I used don't like the first #2, but change it to a 1, and they all come up with this:
1 = Chevrolet
H = 1987
N = Norwood Ohio
230574 = Last 6 digits of the vehicle VIN #
P.S. It's possible that the decoder that I used was biased towards Chevrolet!! LOL!! Just substitute Pontiac for Chevrolet, and Firebird for Camaro!! The engine suffix code is what you really need, and SFW is a 1987 305 with auto transmission!!
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
