1984 Trans Am Build Sheet?
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
Re: 1984 Trans Am Build Sheet?
You are correct. That is the build sheet with all RPO codes and dealership information on the bottom. Some find a similar sized piece of paper with far less information and consider it a build sheet, when it's just a trim sheet that has a fraction of the information a build sheet, such as your example, contains.
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Yes, that is a very nice find. Other than the water spot in the center of the page, that build sheet is very legible.
Have you found one for your car?
Car: 1984 Trans Am
I have been looking, but have not found a build sheet to my car. Someone removed the original seats long before me, so I have been piecing it back together. However, my car has many of the same features since both were from 1984. My production sequence is 272421 and the build sheet is 252459, so there is a difference of 19,962 between the two both built in Van Nuys.
The car I got the build sheet (252459) from had all its original parts from the factory, but got left in a field for 15-20 years unprotected and the sun ate the exterior. The owner decided to part it out instead of restoring it, which workout well for me.
Car: '95 Impala SS
Engine: 350/LT1
Transmission: (Sold my '89 Formula 350)
Yes, VERY legible. You can even read the shipping weight: 3475 lbs.
Wonder why they recorded it separately, 2035 front, and 1440 rear ?
Does that have something to do with the auto transport trailer?
Car: 1984 Trans Am
I spoke with my buddy who has been driving truck for 20+ years. He said it is for the auto transport trailer. That is why you see some cars facing forwards or backwards, so the weight can be distributed on the trailer.
Guest
Posts: n/a
That's interesting. I always wondered if it was just for fit, or the whims of the people loading, or what.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I see your Build sheet states L69 W/ Automatic Trans... But your info on the left states L69/T5 Did you replace the trans with a manual?
Kewl Find BTW, I have the one from one of my cars, not looked in my convertible... I suspect it is gone...
John
John
Car: 1984 Trans Am
No, I still have the manual. Pretty much the only difference between the two cars. I really like the manual. A lot of fun. Hey, can you post your build sheet? I'm curious to see what it looks like.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I found mine over 20 yrs ago, but it was under the carpet, pass floor board.Prodcution workers put them in all sorts of places.Some have been located on top of the fuel tank.So you(OP) may still have yours...somewhere.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Probably.Easier than having to throw it away maybe.
I always thought its what employess used along the production line.So they know what options the car needed.Then just left it inside for future finds.
In the seat springs, under the carpet on the passenger side, (where the catalytic hump converter is), under the back seats, under the carpet in the hatch area... pick one... its hidden... I have even head of behind the front bumper cover
The only thing I could think of was the trash can was full, so they stuffed it in the car... It was definitely not a standard thing where all cars got it, if it was then everyone should find one, unless someone else found it...
John
...The only thing I could think of was the trash can was full, so they stuffed it in the car... It was definitely not a standard thing where all cars got it, if it was then everyone should find one, unless someone else found it...
John
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
That's pretty cool. I have an 84 T/A as well. I've re-done my interior and haven't found one for mine so I figure mine's long gone. I saw on the sheet it said Boise ID. Is that where your from? I'm from Idaho and moving back to that area in about a year when I get out of the Air Force.
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
John
John
I haven't removed the gas tank yet, so maybe I'll find the build sheet here.
On my 84, I found it folded under the carpet on the PS tunnel but with the moisture of the deadener, it stayed glued to the floor.
It seems like there are better chances to find them in a Van Nuys car than in a Norwood car.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
