is it a real 1LE
Old Aug 15, 2010 | 01:34 AM
409belair's Avatar
is it a real 1LE
does the vin have a code in it for the 1LE option.
or were should I look to find it.
Old Aug 15, 2010 | 01:36 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Re: is it a real 1LE
Can't tell by vin look at rpo's in the glove box or trunk.
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
rpo codes should be on the rear glove box or in the arm rest compartment it will have a list of 3 digit codes, if it says 1le than it is
Old Aug 15, 2010 | 01:41 AM
409belair's Avatar
thanks
Old Aug 15, 2010 | 08:33 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Be sure the VIN on the SPID (RPO label) matches the one on the car just to confirm it's 100% correct.
It's not uncommon for the part the label is on to be swapped from another ride over the years. In that case it would be useless.
Old Aug 16, 2010 | 08:59 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Also I would strongly consider verifying the 1LE specific parts, like the 12" front brakes, and aluminum driveshaft. Although these things could be changed by any owner, its a tell tale sign. Also the Aluminum driveshaft was available without the 1LE...
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
