1989 formula 350 with rear disc brakes worth anything??
Old Sep 12, 2010 | 04:53 PM
DEAD SPACE's Avatar
The deal is not done yet. But I found a formula 350 with rear disc brakes.
I seen alot of formulas with drum. Did only the 350 formula come with disc??
Are these cars worth anything?? were they a special model.
Reason I ask Is I dont need the whole car. Im buying just for the motor and trans.. I figure if its not a special car, I will part out the rear or sell as a whole. Help me out guys!!
Old Sep 12, 2010 | 05:04 PM
Guest
Guest
Posts: n/a
Re: 1989 formula 350 with rear disc brakes worth anything??
The 350 would have required the car to have rear disc brakes that year.
Old Sep 12, 2010 | 09:55 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Why part it? A Formula 350 is a desireable piece to have...
Old Sep 13, 2010 | 06:56 PM
DEAD SPACE's Avatar
Did not know that. But I dont need the whole car!!
Old Sep 13, 2010 | 07:51 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Actually there are probably more 1989 Formula 350's out there over any given year. If the car is beyond restoring, and cheap, go to town.
John
Old Sep 13, 2010 | 07:53 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
But if it's decent, please don't take it apart. Too many decent cars have been getting parted out lately.
Old Sep 13, 2010 | 08:47 PM
Drew's Avatar
Define special? The Formula in general is unique in that it's the only Firebird offered with all the performance equipment, and the only Fbody offered with all the performance equipment WITHOUT the ground effects found on the Trans Am's and late Camaros. It's pretty much a special model of the Firebird offered to compete with the best Ford had to offer. I'd say that makes them special.
Drum brakes are a lot more common. The early disc brakes are total garbage, and the later PBR disc brakes had supply problems, so there aren't that many 89-92 cars with good rear disc brakes. It makes the car a little more unusual, but not really rare.
Unless the car is trashed, it'd be a shame to chop it up. It may be fairly common, and not worth a lot, but there's nothing special about the engine/transmission to make it worth sacrificing the car. Most people with L98's and 700R4's want to upgrade to something better anyway.
Old Sep 13, 2010 | 08:53 PM
DEAD SPACE's Avatar
Ill post pics soon. thanks for the reply!!
Old Sep 14, 2010 | 01:31 PM
okfoz's Avatar
To add to Drews comment, there were two rear disc brake systems in 1989. Although they appear the same, The first design was underpowered, the prop valve and other things were out of balance for the front/rear ratio. THe later version was actually much better. I might have a the serial number breakout of when the changeover was made. I would have to check tho.
Keep in mind that from 1982 - 1988 there was the first design 10.5" rear disc brakes, starting in 1989, they went to the 11.75" rear disc brakes which was much much better.
John
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
okfoz
Mar 9, 2017 02:35 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
