Dumb question about Firebird steering wheels...
Old Sep 22, 2010 | 10:21 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
An 87 GTA steering wheel is the same design and fits the same as an 86 TA, correct? Only the horn button is different in emblem? I assume my horn button from my 86 will fit?
They LOOK the same, but before I buy this GTA wheel I want to know for sure it'll work...thanks!
Old Sep 22, 2010 | 10:24 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Re: Dumb question about Firebird steering wheels...
Yes. I took a Firebird steering wheel that had been put on my '88 GTA and put that one onto my '84 T/A. So, yes, you can switch them.
However, depending on the GTA wheel, if it has the radio controls, you need the wiring harness behind the wheel and I haven't delved into what else may be required for wiring harness changes.
Old Sep 22, 2010 | 10:32 PM
Jason E's Avatar
Its an 87 so it does not have the audio controls in the wheel center. Thanks for the quick answer! My 86's wheel is shot, and I found a halfway decent grey leather GTA wheel....I assumed it would work but wanted to ask anyway,
Old Sep 22, 2010 | 10:35 PM
GTA50's Avatar
With an '87, you're good to go! That gold bird on the horn button does look sharp.
Old Sep 22, 2010 | 10:41 PM
Guest
Guest
Posts: n/a
The 87 GTA didnt have wheel controls.
I have an 87 GTA wheel in my 86TA. Its identical.
Old Sep 22, 2010 | 10:43 PM
Jason E's Avatar
It does look nice, but I'm going to swap my 86 regular button on for a stock look. With such low mileage on this thing, I've decided a light, stock resto is the way to go with this car.
Thanks to both of you for your help...this is likely the dumbest, no-brainer question I've asked on here in my 10 years here
Old Sep 26, 2010 | 09:23 PM
hardon85's Avatar
I thought in '87 steering wheel controls were an option???
Old Sep 26, 2010 | 09:40 PM
AmorgetRS's Avatar
I don't see it as an option on the GTA Source Page:
http://www.gtasourcepage.com/87optionspriceinfo.html
Old Sep 26, 2010 | 11:52 PM
Guest
Guest
Posts: n/a
1988 first saw the addition of the RPO UK3 steering wheel hub-mounted radio controls that were standard on the GTAs equipped with the UT4 cassette radio through 1989. Be sure to look for these controls if the car is purported to be one of these models.
From the same place. Probably the most accurate information is on that website.
Old Sep 27, 2010 | 12:18 AM
hardon85's Avatar
Ok thanks for the clarification guys. the only reason I thought this was I know in '87 you could get the GTA pretty stripped down option wise if you wanted to and in '88 they had a lot more standard features.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
