1987 Base Camaro with IROC suspension
Old Nov 15, 2010 | 07:26 PM
camaro18020's Avatar
Car: 1987 IROC-Z/1984 Z28/1987 V6
Engine: 350(5.7)/305(5.0)/173(2.8)
Transmission: 5speed/700R4/700R4
Axle/Gears: 4.10/3.73/3.73
i was wondering if any buddy had any information about the 1987 camaro test that was built in Calif. As i was working on my 2.8 i noticed somethings that ur not normal for the 2.8. It as the iroc suspention and interior. I called the owner of the car before me and he did tell me that this is a real test car. The car is all factory. The car is about 2500 pounds lighter than my 1987 iroc z. If anyone has any specs on the car would love to know. This car is too quick for ur stock 2.8.
Old Nov 15, 2010 | 08:18 PM
yo soy el warg's Avatar
Re: For All 1987 Camaro Owners>>
If this car is 2500 lbs lighter than your Iroc it must have been made out of some super carbon fiber or some new light weight titanium! I see why it is so quick and must be a test car. It wouldn't be safe to be driven on public roads unless it has a roll bar and 1LE brakes! My 2 cents worth.
Old Nov 16, 2010 | 12:20 AM
Drew's Avatar
First, if you're going to ask a new question that really has nothing to do with a pre-existing thread, just start a new thread. Otherwise you're hijacking the thread and you probably won't even get an answer.
Second, it sounds like someone fed you a bunch of ... As a general rule, r&d test mules weren't sold to the general public, when GM was done with them they were destroyed since they weren't emissions certified. An average Iroc weighs about 3400-3600lbs, so 2500lbs lighter would be a 1000lb car. Even econo-boxes weigh more then that.
Stop trolling.
Old Nov 16, 2010 | 10:09 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Stop trolling.
Without Paperwork its a V6 Camaro, with IROC suspension donated from another car. It sounds interesting, however the plausibility of the existence of the car may be in question. I Do know that there are cases where cars got options or things that were not normally installed. There are cases where they run out of screws and simply raid local hardware stores to keep the line running. I also know of cars that got special paint from the factory (not third Gens) And I am pretty sure there is a Camaro out there with a Firebird interior or a Firebird with a Camaro interior that was done in error. Also there are cases where the Factory may run out of a certain part and simply use something else in its place, For example if they ran out of the ultra light "GTA" type spoke wheels they may opt to put Formula rims on a Trans Am. The possibilities are endless.
With all that said, were not talking about nuts or bolts, or a special paint code. If you post your SPID sheet it may answer some questions for you. For example if the car came from the factory with the FE2 suspension then your SPID should show FE2, and without the Z28 option then that may be an unusual find.
Also keep in mind that there was some cars in 1987 that got the RS badges, there is really little known (by me) what the RS entailed in 1987, it may be special suspension, but I suspect not. I do want to think it came with the ground effects however like the Z28/IROC.
SHow me a SPID in your center console, it will answer almost all questions.
John
Old Nov 16, 2010 | 10:44 AM
This time I won't be in such a joking manner like I was above. If your car is one of the few 1987 RS models that got built with a V-6 and was only for California sales it will have the RPO Z5C on its SPID. I also think they came with the Z-28 steering wheel and not the sport coupe style steering wheel.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
