Rear end code metal tag reproduced?
Car: '92 Formula, '92 TA, '91 ZR-1
Engine: 350, 305, LT-5
Hi everyone,
Is there anyone out there who reproduces the metal ratio tag that attaches to the rear end housing via a cover bolt on some third gens? If not, this may be a good item for someone who has access to metalworking equipment to start producing.
Car: `86 SS / `87 SS
Re: Rear end code metal tag reproduced?
AFAIK, the cover bolt tag only indicated limited slip (reproduced already) and the ratio code was stamped in an axle tube.
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Quoting the GM bulletin I have, "Divisional Manufacturer code letters will be metal stamped on the axle tube adjacent to the carrier for field identification. Metal stamped on right front inboard side letters and numerals 1/4" high, 3" outboard of carrier or are located on a metal tag attached to cover bolt". I wonder why they used two different methods?
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
