I have a question/want advice.
Car: 1989 IROC-Z Camaro
Engine: 5.7 350 TPI
I have just acquired an '89 IROC-Z Camaro. (It contains the 5.7 350 Engine.)
First question I have is where would the RPO sticker be located?
It has no glove box and there is only a Service Parts Identification sticker in the center console. (I would like to check if it is an 1LE.)
Its been sitting in a garage for 8 years, so we went over today and did some maintenance work on it. Then got it to run. I'm going back during this week to get it registered and inspected then i will be able to drive it home.
Re: I have a question/want advice.
The black/white sticker on the inside wall of the center console that you found is what others refer to as the "RPO" sticker as it contains a list of all RPOs for that vehicle.
Car: 85 Z28
Engine: 327
You can also look up all the codes to see what car originally was. There are a few sites for it. Tells you what gears you have, what options, etc. It can be overwhelming. My sticker has about 100 codes, but it was fun to see what my car was born as for it has changed a lot since 1985
Engine: 5.7 350 TPI
