need help! build date questions
ive posted in the cars wanted that im looking for a camaro to do a memorial build for my late son, im looking for a z28 or rs that was built in 11/91, the month and year he was born. im assuming being that late in the year that i need to look for a 1992 model?? or does anyone know if they made any 91 models that late in the year??? or were can i find the info i need?
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: need help! build date questions
I'm sorry to hear of your loss and good luck in your search. With a build date in November you would be looking at a '92 model year Camaro. The SPID should give the build date (make sure the VIN on it matches the car). The definite spot I know of would be the ID decal on the driver's door which shows build month/year (again make sure the VIN on the decal matches the car). This is usually the same decal with the tire/wheel info but can be a separate decal mounted in the same area on the door.
Car: '84 Z28
Engine: L69
I too am sorry for your loss, and what a great tribute to your late son. Definetly a '92 year model you're looking for. Looking through my build sheets of '92 Camaros I've collected you're looking for a VIN sequence of about NL117000 to about NL121000. I can get a more exact figure for you on the November build when I get to work tomorrow and I'll post that for you.
David
David
David
David
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
