Found buildsheet
Old Aug 8, 2011 | 09:26 PM
davidj3594's Avatar
Found buildsheet
I just pulled my build sheet out of my 87 iroc ,it was under the seat but unfortunatly it was ruined since the car has power drivers seat and I guess the heat ruined it.anybody know where I could find another one(if it's possible it has 2?)It's a van nuys car.If not is there a place to figure out what the car was originally equipped with using the vin(can't use compnine since it doesn't work on cars before 1990)It's an 8 in the eight digit of the vin so I know it's a legit iroc but the center console is long gone
Old Aug 8, 2011 | 11:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Found buildsheet
Be thankful you found that one!
Old Aug 9, 2011 | 06:34 AM
lha1992's Avatar
Alot of these cars came with 2 build sheets in the car. One under the drivers seat and the other behind the back seats. To get to the one in the back you will have to take the bottom cushions off an then take the back rest off an it will be in between the foam and the springs.
I know this was the case when we found my friend's buildsheets in his '80 Z28. Could also still be the case in a third gen too.
Old Aug 9, 2011 | 11:08 AM
Drew's Avatar
Why bother? Seriously, you could hunt forever, tear the car apart and never find one. Or find one that's not legible. It's not worth the trouble obsessing over it. If you really want to know more about the car, try getting a copy of the invoice from GM.
Old Aug 9, 2011 | 02:32 PM
davidj3594's Avatar
Thanks.I don't think there is any in the backseat since i took the rear seats off to check out the floorpans underneath.the only things readable are iroc and nnl,xu and hs30.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Abubaca
Nov 5, 2016 12:22 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
rudolphschenker
Sep 4, 2015 02:41 AM
