85 IROC coming out of storage ??
Old Oct 5, 2011 | 01:19 PM
malushi333's Avatar
Car: 85 CAMARO IROC-Z
Engine: 5.0L LG4 TBI
Transmission: A4
I just inherited my dads 85 iroc-z, i believe it has a LG4 with an A4. Its in great shape, has 78,000 original miles (mostly highway) and definitely never beat on. It was never properly prepared for storage. Now it hasnt been started for maybe around 5-7 years. What will be necessary before trying to start it, like what do i need to do? What are some problems i could be facing? Is there a possibility that the engine is ceased ?
Old Oct 5, 2011 | 05:45 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: 85 IROC coming out of storage ??
You need to drain the gas from the tank, change the oil, give it a tune up (plugs, wires, cap and rotor). I would also flush the radiator but thats not as critical as changing the oil and draining the gas tank.
Plan on new tires soon too because the ones on there now will most likely be dry rotted and will have flat spots.
Old Oct 5, 2011 | 08:41 PM
malushi333's Avatar
Transmission: A4
thanks for all the info, is there a chance of my engine being ceased and if so how can i check ?
Old Oct 5, 2011 | 09:06 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
it will either turnover or it wont...you will know pretty quickly if its seized
Old Oct 5, 2011 | 09:23 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Remove the sparkplugs and squirt some WD-40 in the holes and let it soak.
BTW, let's see some pics!
Old Oct 6, 2011 | 03:08 PM
malushi333's Avatar
Transmission: A4
thanks for all the help and ill try to get some pics but we recently just stored my brothers 300zx in our garage so its a little cramped lol..
Old Oct 7, 2011 | 12:39 PM
oscar_a_wiggy's Avatar
Car: 2004 F150 and 1970 El Camino
"Remove the sparkplugs and squirt some WD-40 in the holes and let it soak. "
wd40 is OK but i would use "fogging oil". i do this to my elcamino each year when i store it. wd40 has other chemicals in it besides lubricant that displace water (that's what the wd stands for "water displacement") you can get foggin oil at any hardware store.. like true value. more info at the link....
http://www.amsoil.com/storefront/fog.aspx
if you can't find it just shoot some regular motor oil in there.... it'll smoke when you start it but it will go away.
also, don't forget to look at the brakes.... and tires can start to dry rot in as few as 7 years, so check them too.
oaw
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
NBrehm
Aug 5, 2015 07:57 PM
