WHAT IS COMPATIBLE?
Old Oct 6, 2011 | 08:44 PM
joekaz1070's Avatar
Car: 1987 Trans am
Axle/Gears: GM 10 bolt
WHAT IS COMPATIBLE?
Hey everyone,
I have an 87 Trans Am. Will the stock cross-member, lower control arm and disc assembly from any Trans Am between the years 82-92 be an equal swap bolt for bolt. Also would the same apply for rear ends. Any info would be greatly appreciated.
thaks, Joe
Old Oct 6, 2011 | 09:31 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: WHAT IS COMPATIBLE?
Originally Posted by joekaz1070
Hey everyone,
I have an 87 Trans Am. Will the stock cross-member no, lower control arm yes and disc assembly yes from any Trans Am between the years 82-92 be an equal swap bolt for bolt. Also would the same apply for rear ends yes. Any info would be greatly appreciated.
thaks, Joe
These are my guesses. More accurate info from other members to follow.
Old Oct 6, 2011 | 09:58 PM
AmorgetRS's Avatar
cross member is the same, too.
Old Oct 6, 2011 | 10:04 PM
joekaz1070's Avatar
Car: 1987 Trans am
What were your thoughts as to why the cross member would not fit?
Old Oct 6, 2011 | 10:09 PM
AmorgetRS's Avatar
All of the V8 cross members are identical... I have no idea why he would think otherwise.
Old Oct 6, 2011 | 10:11 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Lots of different trans between 82-92.
Old Oct 6, 2011 | 11:31 PM
AmorgetRS's Avatar
I don't think he is talking transmission cross member, I assume he is talking the engine cross member that the a-arms attach to, judging by the parts he listed.
Old Oct 7, 2011 | 12:26 AM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
From my observations (V-6 and V-8 Firebirds), the K-frame is identical. The differences come in springs, etc.
For the transmission cross-member, the difference is betwen automatic and manual - assuming there is a difference (my cars are all manual).
Old Oct 7, 2011 | 12:43 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I just put a cross member from a 92 Z28 350 on my v6 with a t5, and it fit perfectly...
Old Oct 7, 2011 | 09:47 AM
Drew's Avatar
Usually parts will bolt up the same. Sometimes later parts might not bolt up to an earlier car which lacks provisions. To be a truly identical replacement you'll probably want to stick to cars of nearly the same age, with the same options. Any differences are probably going to be subtle, and most people might never notice a difference, but that doesn't mean they're exactly the same.
Old Oct 7, 2011 | 07:37 PM
joekaz1070's Avatar
Car: 1987 Trans am
Thanks for the replies. I did mean the engine K-member.
tmellott89
Oct 14, 2015 02:06 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Formula_88AE
Sep 3, 2015 01:47 PM
