Water in trunk and passenger side floor
Old Nov 28, 2011 | 05:13 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Ok so i already looked underneath the and there is no visible rust. The carpet floor, floor only was wet. I think the water is comming from the bottom not the top because there is no streak marks.
How do i go about finding the leak spot and fixing it?
Old Nov 28, 2011 | 05:25 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Water in trunk and passenger side floor
What kind of roof on car? Hard top or TTop? Pass side carpet? Dr side? front DR or Pass? rear dr or pass? hatch carpet?
If the top of the carpet is wet but the bottom isnt your leak is from the top.
It sounds to me like your deck lid to glass seal is bad (trunk water) and your body to hatch hinges are leaking.
TTops maaaybe leaking also if you have them.
A GM service manual from HELM INC is veeery helpful and worth the money.
Old Nov 28, 2011 | 09:15 PM
AmorgetRS's Avatar
Are you sure the passenger side floor wasn't coolant? If the heater core goes the passenger side foot area will get wet with coolant.
Old Nov 28, 2011 | 11:59 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Look at sidemarker lights, they will allow water in surprisingly.
Old Nov 29, 2011 | 08:26 AM
TTOP350's Avatar
That wouldn't get water on the hatch carpet tho. It would drain out of the holes in the spare tire well (pass side) or the locking compartment quarter panel hole (dr side)
Old Dec 4, 2011 | 02:07 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Check if the wheel wells are rusted.
For the passenger side floor, most likely somewhere in the firewall. Maybe somewhere by around the heater box.
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Cameeeero
Aug 20, 2015 03:06 AM
Nj1987
Aug 19, 2015 08:26 PM
Street Lethal
Aug 14, 2015 08:25 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
